Platinum Tooling Expands Product Lineup to Deliver Greater Machining Flexibility!
Friday 10 October 2025, 8:45:08 AM
Platinum Tooling has unveiled its latest product catalog, showcasing an impressive range of high-precision tooling solutions designed to enhance flexibility and performance across modern machining operations. As the exclusive importer and master distributor for several globally renowned brands, the company continues to strengthen its position as a one-stop destination for advanced tooling technologies that cater to diverse industries and machining applications.
At the heart of Platinum Tooling’s premium lineup are live tools and angle heads from Heimatec, engineered for the most demanding operations in turning, drilling, and milling. Heimatec’s live and static tools cover a full range of machine types, from compact Swiss-type CNC lathes to large live-tool lathes. Their precision-engineered angle heads are built to handle complex applications, offering reliability, accuracy, and durability in even the toughest production environments.
Complementing these are Tecnicrafts’ Swiss-type collets and guide bushings, available in standard and ultra-precision variants that achieve a runout accuracy of 5 microns or less. Designed for versatility, these collets come in various bore profiles — including round, square, hexagonal, rectangular, and fully customized options. Each guide bushing features a chamfered back bore and slitted design, ensuring smooth guiding and reduced marking, making them ideal for high-speed Swiss machining.
For manufacturers seeking increased spindle speeds and optimized cutting performance, Platinum Tooling offers Henninger’s range of speed increasers. Available in air, mechanical, and high-frequency motor configurations, these spindles help operators reach higher cutting tool RPMs required for advanced materials and fine finishing applications. The precision of Henninger technology enables manufacturers to achieve improved surface quality and shorter machining times without compromising tool life.
The lineup also includes the Quick series of knurling and marking tools from Hommel + Keller. Recognized for their exceptional craftsmanship, these tools meet the most stringent quality standards for both form and cut knurling. They allow machinists to create crisp, repeatable patterns and permanent markings on a variety of surfaces and geometries — achieving results within seconds while maintaining high repeatability.
Rineck adds further versatility with its standard and custom shrink-fit toolholders, compatible with multiple machine interfaces such as CAT, HSK, BT, SK, PSC, and straight shank extensions. Rineck’s shrink-fit machines are designed for operator convenience, featuring elevation cooling systems that allow heated tools to be transferred automatically into cooling tanks at the push of a button, streamlining setup and minimizing downtime.
Dunner’s expertise in Swiss-type CNC lathes is reflected in its precision guide bushings made from bronze, ceramic, and titane (Meehanite) materials. Each bushing is prefinished and ready for machine use, ensuring stability and exceptional performance across a wide range of part materials and tolerances.
Finally, REV broaching tools complete Platinum Tooling’s diverse catalog, offering efficient solutions for machining internal and external profiles such as keyways, splines, and hexagons. These tools are designed for simplicity and versatility, supporting both standard and custom profile production.
With this expanded portfolio, Platinum Tooling reinforces its commitment to providing high-quality, application-specific solutions that boost productivity, precision, and profitability for manufacturers worldwide.
