Platinum Tooling Expands Heimatec Angle Head Inventory to Boost CNC Machining Efficiency!
Monday 13 October 2025, 8:00:03 AM
Platinum Tooling has announced a major expansion of its Heimatec angle head inventory, now offering a wider range of models ready for immediate delivery from its headquarters in Prospect Heights, Illinois. The newly designed standard and custom angle heads are engineered for high performance and versatility, meeting the diverse demands of CNC machining centers across industries. Available in all common spindle tapers, including CAT, HSK, and BT, these angle heads are built to deliver superior precision, durability, and adaptability in modern machining environments.
The expanded lineup includes an array of compact models weighing under 12 pounds—ideal for use with automatic tool changers—making them suitable for high-speed, automated machining setups. Platinum Tooling’s selection also features extended-reach, slim-line, dual-output, and universal adjustable designs, catering to a variety of complex machining applications. In addition, specialized models are available for heavy milling, deep drilling, and tapping operations, ensuring comprehensive coverage across different manufacturing needs.
A key innovation across many Heimatec angle heads is the incorporation of the company’s patented u-tec changing system. This system enhances tool flexibility by allowing operators to change output spindles quickly and easily, significantly reducing setup time and maximizing machine utilization.
Built from high-tensile-strength aluminum, the Heimatec angle heads combine lightweight construction with exceptional rigidity. Their precision spindle bearings ensure optimal concentricity, improving machining accuracy and extending tool life. Inside, the gears are crafted from hardened, ground, and lapped high-resistance gear steel with inclined teeth, which provide smooth, efficient, and reliable power transmission even under demanding cutting conditions.
Each model comes equipped with a full 360-degree body rotation capability and a positive compression locking system for secure positioning. Operators can also achieve 90-degree incremental repositioning without the need for re-indicating, streamlining setup and alignment. Additional standard features include maximum torque ratings up to 150 Nm, spindle speeds reaching 24,000 rpm, a 1:1 gear ratio (with other ratios available), and interchangeable torque arms for added flexibility.
By expanding its inventory, Platinum Tooling reinforces its commitment to providing quick delivery and reliable solutions for CNC users who demand precision and productivity. With this updated range of Heimatec angle heads, manufacturers can perform intricate machining operations more efficiently, handle challenging geometries, and reduce tool changeover times—all while maintaining consistent accuracy and performance.
This expansion highlights Platinum Tooling’s focus on supporting the evolving needs of modern manufacturing, where flexibility, speed, and precision are essential for maintaining a competitive edge.
