Platinum Tooling Enhances Machining Versatility with Heimatec BMT Products!
Friday 17 January 2025, 2:21:59 PM
Platinum Tooling Technologies Inc. has expanded its portfolio with the introduction of Base Mount Tooling (BMT) products from Heimatec. These advanced live tooling solutions are engineered to provide versatility and precision, catering to a variety of machining applications. Available in standard sizes, including BMT 45, 55, 65, 75, and 85, the tools offer reliable performance for a broad range of operations.
All Heimatec BMT tools come equipped with the U-Tec changing system, which enables quick and seamless adaptation to various machining needs. This innovative feature allows operators to switch outputs easily using adapters for Face mills, Weldon side lock and ER collet extensions.
The result is improved workflow efficiency, reduced downtime, and streamlined tooling inventory management.
The BMT tools are designed to withstand demanding machining environments. Key features include:
  • Adjustable tools for greater customization
  • Speed increasers to enhance efficiency
  • Internal coolant tools with a capacity of up to 140 bar (2,000 psi)
Additionally, the tools feature a polygon drive connection for superior power transmission and an internal collet nut design that positions the cutting tool closer to the bearing. This design enhances rigidity, extends tool life, and ensures a high-quality surface finish.
Manufactured at Heimatec’s state-of-the-art facility in Germany, the BMT tooling reflects superior craftsmanship and precision. These tools are now readily available through Platinum Tooling’s Chicago-based headquarters, ensuring swift delivery and expert support for the North American market.
With its innovative features and robust design, the Heimatec BMT series is ideal for applications requiring adaptability, precision, and reliability. By integrating advanced technology and user-friendly features, Platinum Tooling continues to empower manufacturers to achieve greater efficiency and productivity in their machining operations.
