Okuma Expands Robot Loader Series to Enhance Machining Productivity and Efficiency!
Friday 12 September 2025, 1:00:27 PM
Okuma America Corp. has strengthened its automation portfolio with the introduction of its Okuma Robot Loader (ORL) Series, a family of pre-engineered systems designed to automate the loading and unloading of parts from Okuma machines. Developed to address the growing demand for higher productivity, reduced labor dependency, and increased machining efficiency, the ORL lineup offers manufacturers across industries—including automotive, aerospace, medical, and general engineering—a reliable, entry-level automation solution that is both simple and effective.
The Okuma Robot Loader Series is designed to integrate seamlessly with Okuma’s machining platforms, allowing customers to scale automation according to their production needs. By automating repetitive tasks such as loading raw materials and unloading finished parts, these systems enable operators to focus on higher-value activities while minimizing downtime and setup delays. The result is a boost in throughput, improved part quality, and significant cost savings over time.
For high-speed, high-volume applications, the ORL-R (Rotary) model features a rotating platform with a disc-style storage unit. This setup allows operators to provide raw material and remove finished parts while the robot simultaneously handles machine loading and unloading, maintaining uninterrupted production flow. Capable of managing up to 166 workpieces on a lathe, mill, or grinder, the ORL-R supports part lengths ranging from 0.75 to 11 inches with a handling weight capacity of 8 to 33 pounds in dual-handling mode. With a footprint of 132 × 90 inches, it pairs effectively with Okuma’s Genos L and LB series, making it an ideal solution for shops seeking high-volume consistency.
For dual-process operations, the ORL-D (Drawer) model is designed with a drawer-style storage system that organizes and holds parts efficiently. This configuration enables the robot to load and unload the machine while operators simultaneously manage parts in the drawer, reducing idle time and streamlining workflow. The ORL-D can accommodate 92 workpieces with templates that extend capacity to 180 smaller or 42 larger parts. Supporting part lengths of 0.75 to 6.25 inches and a handling weight capacity of 8 to 33 pounds, the ORL-D occupies a footprint of 144 × 72 inches. It is designed to pair with Okuma’s Multus B, LU EX, LT EX, and LB EX series, offering an adaptable solution for complex, multi-process production environments.
For manufacturers dealing with mixed parts and low-volume automation needs, the ORL-MC (Machining Center) provides maximum flexibility with a three-sided rotating station. This setup enables parallel loading and unloading of multiple operations with automatic changeover for different part types. With a capacity of up to 288 parts and handling dimensions of 8.5 × 8 × 9 inches, the ORL-MC supports part weights of up to 25 pounds, including jaws. Its footprint of 96 × 108 inches ensures efficient use of floor space, and it pairs seamlessly with machining centers such as the Genos M460-VE, Genos M460V-5AX, Genos M560-V, Genos M560V-5AX, MB-46V II, and MB-56V series.
By offering these three versatile models, Okuma provides manufacturers with automation options that align with varying production scales, part geometries, and throughput requirements. The ORL Series underscores Okuma’s commitment to supporting its customers’ digital transformation journeys, empowering them to achieve greater efficiency, profitability, and resilience in a competitive global market.
