New iwis antriebssysteme maintenance-free storage chains: Polymer bushings in each link for extended service life
New iwis antriebssysteme maintenance-free storage chains: Polymer bushings in every link for extended service life | b.dry: the polymer sleeves in each joint lengthen the service life of the chain
Munich chain manufacturer iwis antriebssysteme GmbH & Co. KG is expanding its range of products. With the new version of its JWIS accumulation chains in quality b.dry, customers can now enjoy the considerable benefits of maintenance-free and corrosion-resistant stainless steel chains, which are completely dry, have a high wear resistance and are capable of bear significant dynamic loads. In addition, thanks to the high-performance polymer sleeves in each joint, they require no initial lubrication or regreasing. Because industrial, friction and high performance polymer bushings are FDA compliant, there is no risk of contact with food and sanitary products. The new accumulation chains b. Dry are ideal for use scenarios in which regreasing is to be avoided or impossible. Hygienic and dry-running, these chains are ideal for conveyance applications for sensitive products, where the smoke caused by the evaporation of lubricants is to be avoided. This technology is particularly useful in applications involving an online industrial furnace and the resulting accumulation of cooked products.
These new maintenance-free storage chains are distinguished by the presence in each support roll and the accumulation of a b.dry hinge, which guarantees smooth and extremely quiet operation. In applications using accumulation chains, the wear of the accumulation and conveying rollers is much more worrying than that of the chain, because these rollers are in constant motion, whereas the joints at the end of the raceway are move a lot less. The durability of the bdry chains, taking into account the wear, is much greater than that of comparable products: the tests carried out by iwis demonstrated twice as much performance in the dry and four times higher with initial greasing. Dried up, the chains are free from substance disturbing the wetting of the paints (PWIS), a decisive point in particular in the chains of painting of the automobile industry. The b.dry chains comply with the length tolerances of ISO 606 and can be used at temperatures between -100 and +200 ° C. Currently, iwis antriebssysteme offers b.dry technology for M type accumulation chains with de “pitch, 48 mm width and 28 mm diameter steel rollers.
The Munich chain manufacturer offers a wide range of products for drive and conveyor technology: precision and high-performance roller chains, conveyor chains, maintenance-free and corrosion-resistant chains, accumulation chains, specialized conveyor chains, chain link chains, hinged chains and modular belts for industrial applications, chains and accessories for agricultural machinery, chain drives for the automotive sector, etc. iwis is a major player in the global market for innovative and economical timing belts based on precision chains. o iwis motorsysteme GmbH & Co. KG, which produces chains and timing belts for automotive engines.
o iwis antriebssysteme GmbH & Co. KG, which manufactures roller and precision conveyor chains for industrial applications in the fields of mechanical engineering and factory construction, packaging, printing and printing. agribusiness, and the design of conveyors.
o iwis systemtechnik GmbH, which produces marked / folded sheet metal parts and protective housings for different sectors.
o Unimet Group, which has considerable technical expertise in the field of high-precision sheet metal marking and bending, particularly in electrical connection technologies, force-fit technologies, insulation displacement connections and technologies. MCS contact.
o THIEN eDrives GmbH: electromobility and electric motors
A family business founded in 1916, iwis is currently run by Johannes Winklhofer, the fourth generation of the founding family.
iwis employs more than 2,100 people worldwide and aims for a turnover of 500 million euros in 2019. In
addition to its production sites in Germany (Munich, Landsberg, Wilnsdorf, Sontra, Neugablonz and Rieden), iwis owns factories in the Czech Republic, China and the United States. The company also has subsidiaries in Europe and the rest of the world, notably in the following countries: Brazil, United Kingdom, France, India, Italy, Canada, South Korea, Switzerland, Singapore and South Africa. In total, iwis is present in 45 countries
