Multi-directional CNC turning, have you tried it?
Saturday 12 February 2022, 4:13:40 PM
Tungaloy has launched a new turning tool concept, AddMultiTurn, which features unique insert and toolholder geometries that enable multi-directional turning.
AddMultiTurn provides the flexibility for outer diameter, face and profile turning operations in multi directions, which include high-feed back (pull) turning method, enabling toolpaths that turn in the opposite direction of conventional turning process at higher feeds. Multi-directional turning reportedly optimizes the toolpaths by eliminating air cutting times. The shapes of the AddMultiTurn inserts enable the user to achieve a much smaller entry angle and thinner chips for higher machining efficiency, which spreads load and heat over a longer cutting edge length, providing extended insert tool life.
AddMultiTurn uses two styles of inserts depending on the application, both of which feature a double-sided design with six total cutting edges: 6C-TOMG..TM inserts with 80° nose angle are designed for medium to rough turning and 6V-TOMG..TSF inserts with 35° nose angle is suited for finish turning. Both inserts enable a back (pull) turning method, which the company says can contribute to higher productivity and reduced machining costs compared with conventional ISO turning inserts. AddMultiTurn inserts can also be used for push turning just as with ISO turning inserts.
In addition, the Y-Prism safe lock design provides a rail on the shim and matching slots on the insert, reportedly ensuring tight interlocking and secure clamping of the insert during high productive multi-directional turning.
