Monaghan Tooling Group Offers Reamer Reconditioning Service to Extend Tool Life!
Saturday 31 May 2025, 12:53:58 PM
Monaghan Tooling Group, through its Diatool service, offers a comprehensive reamer reconditioning solution that restores high-performance reamers to original OEM specifications. This service is designed to breathe new life into worn-out tools, ensuring they perform like new while extending their service life. The reconditioning process includes replacing all blades, grinding fresh bevel geometry, refurbishing the body of the reamer, and offering optional coatings for the blades if necessary. This helps to maximize tool longevity and maintain precision.
The reconditioning service is suitable for a wide range of reamers, including solid and expandable monoblock reamers, expandable cutting rings, and replaceable head reamers. By restoring the reamers to their original performance specifications, Monaghan Tooling Group ensures that these tools continue to provide reliable and accurate results, improving productivity in machining operations.
To enhance performance further, Diatool provides advanced coating options and high-quality blade materials such as cermet, coated carbide, and polycrystalline diamond (PCD). These materials reduce cycle times and increase tool life, making the reamers more efficient and cost-effective. The reconditioning process is flexible, with no limitations on how many times a reamer can be reconditioned, ensuring that the tool continues to perform at its peak without compromising quality.
This service is especially beneficial for machining operations facing long lead times or unresponsive tooling vendors. By opting for reconditioned tools, companies can avoid delays and high costs associated with purchasing new tools, while still maintaining high cutting performance. In addition to reconditioning, Diatool offers application consultation to help improve existing tooling with the latest geometries and coatings. The result is higher bore quality, reduced cycle times, and overall savings in cost-per-unit, making this service an ideal solution for businesses looking to optimize their machining operations.
