Mastercam launches Mastercam 2026.R2 with accelerated simulation and AI-assisted programming!
Mastercam has released Mastercam 2026.R2, the latest update to its CAD/CAM platform, introducing faster simulation capabilities and AI-assisted programming tools designed to improve machining efficiency and streamline workflow management. The new release delivers up to ten times faster simulation performance, enabling manufacturers to verify complex machining operations more quickly without compromising accuracy.
Simulation is a critical step in CAM programming, especially when working with multi-operation parts or complex machining strategies. Mastercam 2026.R2 improves this process by providing high-resolution verification while significantly reducing processing time. According to the company, users can now run collision detection, material removal analysis and process verification faster, allowing shops to maintain tight production schedules while ensuring machining accuracy and safety.
A major highlight of the release is the introduction of Mastercam Copilot, an AI-driven assistant designed to automate routine programming tasks. Copilot allows machinists to adjust feed rates and spindle speeds across multiple operations using either voice or text commands. Built-in confirmation prompts ensure safe execution before any changes are applied to the program.
The AI assistant supports approximately 200 different toolpath types and can even generate complete machine groups based on verbal instructions. A hands-free mode can be activated using the keyword “Copilot,” enabling voice-controlled operation that simplifies workflow management and reduces the need for manual input during programming tasks.
Copilot also integrates with the MyMastercam training library, allowing users to quickly locate instructional content. When a question is asked, the system searches the video library and returns results with timestamps that link directly to the relevant portion of the tutorial. This feature eliminates the need to manually search through lengthy training videos to find specific guidance.
For manufacturers working with advanced machining strategies, Mastercam 2026.R2 introduces several performance improvements. These include automatic tilting with bullnose end mills, enhanced four-axis swarf milling capabilities, improved clearance plane calculations and optimized level-based toolpath ordering. Together, these updates are designed to reduce cycle times while improving part quality and machining consistency.
The update also expands machine integration capabilities by adding support for Blum laser tool setters across multiple CNC control platforms. This allows tool setting macros to be generated directly within the Mastercam environment. Functions such as tool height offset measurement, wear checks and breakage detection can now be managed directly through the software, reducing the need for manual program editing.
The integration supports major CNC controls including FANUC, Siemens, Okuma, Heidenhain, Mazak and Makino, helping maintain centralized tool data and simplifying setup processes.
Mastercam 2026.R2 is available immediately and is offered as a free update for customers enrolled in the Mastercam Connect maintenance and support program. The release reflects the company’s focus on integrating AI capabilities, faster simulation tools and deeper machine connectivity to support modern manufacturing workflows.
