LVD showcases Industry 4.0-ready products designed to help sheet metalworking companies advance their business, including the Dyna-Cell robotic bending cell, ToolCell automated tool changing press brake, ultra-high-speed Electra 10kW fiber laser cutting machine, and CADMAN® software at Blechexpo, Hall 1 – Stand 1713.
Dyna-Cell features the high-speed Dyna-Press Pro electric press brake and a Kuka robot. Dyna-Press Pro is now available with LVD’s exclusive Easy-Form® Laser adaptive bending system to ensure bending accuracy. The robot is equipped with LVD’s patent-pending universal gripper able to bend on three sides of a part without regripping. Because one gripper fits all applications, production is continuous and uninterrupted. The compact Dyna-Cell automates bending of small- to medium-sized parts in varying batch sizes at speeds up to 25mm per second. It features an intelligent programming wizard for fast, easy programming of the bending cell. Dyna-Cell follows the 10-10 rule: 10 minutes for CAM generation of the bending and robot program; 10 minutes for set-up and first part generation. Dyna-Cell also allows for unmanned or manned operation, offering a flexible bending solution.
ToolCell automated tool changing press brake maximizes bending productivity through an integrated storage of tooling, housed within the machine. The patented Easy-Form® Laser adaptive bending system provides in-process angle monitoring, which guarantees the desired angle from the first bending operation.
Electra FL with high-power 10kW fiber laser is an ultra-high-speed laser cutting machine that cuts ferrous and non-ferrous metals as fast as the thermal process allows. The machine gantry features a linear drive motor to ensure extremely high dynamics and 2G acceleration while cutting.
CADMAN® makes the virtual factory possible, enabling a constant flow of data between machines and software.
