Italy Vacuum USA Brings Vortex 58 Industrial Vacuum to U.S. Stock for Efficient Chip and Dust Collection!
Friday 24 July 2026, 6:48:45 AM
Italy Vacuum USA has announced that its Vortex 58 industrial vacuum is now available for immediate delivery from its U.S. facility operated in partnership with Kalamazoo Machine Tool. The availability of the high-performance industrial vacuum from domestic stock enables manufacturers to access a powerful and reliable solution for collecting metal chips, dust, and production debris without the extended lead times often associated with imported industrial equipment.
Effective industrial housekeeping plays a critical role in modern manufacturing, where the accumulation of chips, dust, and machining waste can impact productivity, equipment reliability, workplace safety, and product quality. Industrial vacuum systems have become essential across machining, fabrication, additive manufacturing, woodworking, composite processing, and general manufacturing facilities, helping companies maintain cleaner production environments while improving operational efficiency. The Vortex 58 has been developed to meet these demanding industrial requirements by combining high suction performance, durable construction, and large-capacity waste collection in a compact mobile unit.
At the heart of the Vortex 58 is a powerful 4.8-horsepower motor capable of generating an impressive airflow of 1,530 cubic feet per minute (CFM). This high suction capacity allows the vacuum to efficiently collect fine dust, metal chips, machining swarf, and other production waste from machine tools, production floors, workstations, and industrial processing equipment. Strong airflow ensures rapid cleaning while helping manufacturers reduce downtime associated with manual housekeeping activities.
The industrial vacuum is equipped with a large 46-gallon collection container, enabling operators to collect substantial quantities of waste before emptying is required. The generous storage capacity is particularly valuable in high-production environments where continuous machining generates significant volumes of chips and debris. Fewer interruptions for waste disposal help improve productivity while allowing maintenance personnel to focus on higher-value operational tasks.
One of the standout features of the Vortex 58 is its integrated cyclonic separation system, supplied as standard equipment. Cyclonic technology separates heavier particles from the incoming airflow before they reach the primary filter, significantly reducing filter loading and helping maintain consistent suction performance during prolonged operation. By reducing the amount of debris reaching the filter, the cyclonic system also contributes to longer filter life, lower maintenance requirements, and reduced operating costs.
The filtration system itself has been engineered for demanding industrial applications. The vacuum incorporates a high-density antistatic polyester filter certified to Class M standards, providing efficient capture of fine dust particles while maintaining high airflow. The filter material is both oil- and water-repellent, allowing the system to operate effectively in manufacturing environments where coolant mist, lubricants, moisture, and mixed production waste are commonly encountered. The antistatic construction also helps minimise the accumulation of static electricity during operation, contributing to safer handling of fine particulate materials.
Operator comfort has also been considered in the design of the Vortex 58. Oversized low-noise silencers reduce operating sound levels, creating a quieter working environment without compromising suction performance. Lower noise emissions are increasingly important in manufacturing facilities where multiple machines and support equipment operate simultaneously, helping improve workplace conditions for employees.
Durability is another key aspect of the machine’s design. The Vortex 58 is built around a heavy-duty 100% steel frame combined with a reinforced collection container, providing the structural strength required for continuous industrial use. The robust construction enables the vacuum to withstand the demanding conditions commonly found in metalworking, fabrication, and heavy manufacturing facilities, ensuring reliable long-term performance even under intensive daily operation.
To accommodate a wide variety of industrial cleaning applications, the vacuum is available with multiple inlet configurations ranging from 2 to 5 inches in diameter. This flexibility allows the system to be paired with a broad selection of hoses, nozzles, floor tools, machine connections, and specialised accessories, enabling manufacturers to customise the vacuum for specific production processes and cleaning requirements.
The availability of the Vortex 58 from U.S. inventory represents a significant advantage for manufacturers seeking rapid deployment of industrial cleaning equipment. Immediate stock availability reduces delivery times, allowing facilities to quickly implement improved housekeeping solutions, minimise production interruptions, and respond more effectively to changing operational requirements.
As manufacturing facilities continue to prioritise workplace safety, equipment reliability, and operational efficiency, industrial vacuum systems are becoming an increasingly important part of modern production environments. Effective removal of chips, dust, and debris not only helps protect employees and maintain cleaner facilities but also supports longer machine life, improved product quality, and more efficient manufacturing operations.
With the Vortex 58 now readily available from its U.S. distribution centre, Italy Vacuum USA strengthens its ability to support manufacturers with a robust, high-capacity industrial vacuum solution that combines powerful suction, advanced filtration, durable construction, and flexible application capabilities to meet the demanding cleaning requirements of today’s industrial workplaces.
