Introducing Stafford’s Quick-Adjust Products: Effortless Shaft Collars and Mounts for Rapid Adjustments
Stafford Manufacturing Corp., located in Wilmington, MA, has unveiled a new line of shaft collars and mounts designed for effortless adjustment without the need for tools. These innovative Quick-Adjust Products from Stafford feature various options, including the Flip-Lok™ with a split hub and adjustable clamp, the Staff-Lok™ lever-actuated shaft collar, and the Python™ Flange Mounting Collar with a six-hole bolt pattern and keyway.
Ideal for a wide range of linear and low RPM rotary applications, these Quick-Adjust Products offer the convenience of easy repositioning by hand, eliminating the hassle of using tools. Available in both inch and metric bore sizes ranging from 1/2″ to 2-1/2”, depending on the specific product, Stafford Quick-Adjust Products are crafted from black anodized aluminum and can be customized as per OEM requirements, including modifications in materials such as steel and stainless steel.
For applications involving rope, Stafford offers the SlipKnot™ made from ABS plastic, allowing for precise positioning as a grip, locator, or stop. Stafford Quick-Adjust Products, Grip and Go™ Handles, and Thumbscrew knobs are available at competitive prices based on configuration and quantity.
Discover more at www.staffordmfg.com.
Original source www.fabricatingandmetalworking.com
