With the new DMC 90 U duoBLOCK, DMG MORI has developed a package machine that unites all the proven benefits of the duoBLOCK design, high-quality equipment and an attractive price. The strengths of 5-axis simultaneous machining with pallet changer come into play in particular in the fields of die and mold, general mechanical engineering and tool manufacturing. Its powerful standard equipment, the integrated pallet changer and high connectivity make the DMC 90 U duoBLOCK a productive companion in each future-oriented production.
Like all machines of the duoBLOCK series, the DMC 90 U duoBLOCK combines maximum stability and excellent performance. The sturdy design and well thought out cooling system ensure high long-term accuracy. Optionally, an inside cooling with 80 bar and temperature control are available. With 20,000 rpm, 130 Nm and 35 kW, the powerful speedMASTER spindle guarantees high-performance machining. As is the case for all spindles in the MASTER series, it has a 36-month warranty with unlimited hours. Optional spindle versions with up to 430 Nm torque complete the portfolio.
The work area of the DMC 90 U duoBLOCK provides sufficient space for workpieces with a diameter up to 900 x 1,450 mm. The maximum workpiece weight is 1,500 kg. The tool magazine is designed for 60 tools – up to 180 pockets are optionally available – and minimizes the setup time in day-to-day production. Furthermore, the optimally accessible pallet changer enables parallel setup, with which users can significantly increase productivity.
The DMC 90 U duoBLOCK is equipped as standard with the intuitive control and operating system CELOS and SIEMENS 840D solutionline, which enables easy integration into the increasingly digital production. Alternatively, DMG MORI also has a HEIDENHAIN TNC 640 on offer. The DMG MORI IoTconnector is included in the range of features for optimum digital integration. The sensor package i4.0 ensures improved accuracy and increased process reliability. DMG MORI technology cycles such as the 3D quickSET or the maintenance package I4.0 round off the offer.
