Haimer Optimizes Shop Efficiency with VIO Linear 20|70 Tool Presetting Machine!
At Eastec 2025, Haimer USA showcased its advanced tool presetting solution, the VIO Linear 20|70, designed to streamline setup processes and boost overall shop floor efficiency. This high-precision tool presetter combines robust engineering with cutting-edge software integration, making it an ideal solution for modern manufacturing environments where accuracy, speed, and integration are key.
The VIO Linear 20|70 is engineered to provide reliable, repeatable measurements of tool length and diameter, which are critical for ensuring accurate machining operations. Its robust linear guide design, coupled with high-resolution camera optics, allows for precise measurements with minimal deviation. The user-friendly touchscreen interface makes it easy for operators to set up and monitor tools, offering both convenience and precision in a compact design.
By offering repeatable measurements and precise data collection, the VIO Linear ensures that tools are set up correctly from the outset, which reduces setup times and prevents costly errors during machining. This increased reliability in measurements directly translates to improved productivity and better overall performance on the shop floor.
A standout feature of the VIO Linear 20|70 is its seamless connectivity with WinTool software, which enables smooth data transfer between the tool presetter and CAM systems as well as CNC machines. This digital integration eliminates the need for manual data entry, reducing the risk of human error and ensuring that manufacturers maintain consistent, optimized tool data across their operations. By streamlining data management, the VIO Linear helps create a more connected and efficient manufacturing process.
The integration of the VIO Linear with WinTool allows for a direct link between the tool setup process and the production floor, making it easier for manufacturers to optimize their operations. With less time spent on manual data entry and fewer chances for error, the tool presetter helps save time and increase overall shop efficiency.
Designed to handle the rigors of the shop floor, the VIO Linear 20|70 offers precision and durability. Its robust build ensures that it can withstand the demanding environments typical of machining operations, while its compact footprint makes it an ideal addition to any workspace. Whether used in small shops or large-scale production facilities, the VIO Linear is capable of meeting the needs of a diverse range of manufacturing settings.
The machine’s durable construction, combined with its easy-to-use interface, allows operators to quickly adapt to its use, further reducing downtime and improving tool changeover efficiency. The VIO Linear’s advanced features make it a versatile tool that enhances productivity and tool management across a wide variety of applications.
Haimer’s VIO Linear 20|70 brings together German engineering with advanced software solutions to provide a smart, fast, and connected approach to tool presetting. The integration of digital tools ensures that manufacturers can take full advantage of the latest advancements in tool management, improving overall machining accuracy and reducing operational costs. The combination of precision, speed, and connectivity offered by the VIO Linear 20|70 makes it an essential tool for manufacturers looking to optimize their production processes and increase shop floor efficiency.
In conclusion, the Haimer VIO Linear 20|70 is a highly efficient, reliable, and integrated tool presetter that improves setup times, ensures precision in tool measurements, and connects seamlessly with other systems in the manufacturing workflow. By implementing this advanced presetting system, manufacturers can optimize their operations, reduce setup errors, and enhance overall productivity on the shop floor.
