Glebar Company’s new Automatic Work Wheel Balancing System dynamically balances the spindle-through controls of grinding wheels using the HMI. The company says the automated system is more precise than a traditional system, better ensuring repeatable, high-quality surface finishes. As a result, the balanced wheel lasts longer and doesn’t need as frequent dressing.
“The Automated Balancing System reduces the time spent balancing the work wheel by as much as 90%,” says Mark Scanel, vice president and general manager of Glebar Customer Care.
Technicians can use real-time balance conditions as indicated on the HMI to predict when the wheel needs rebalancing before the surface finish degrades. With the Automatic Balancing System, Glebar says operators can balance the wheel successfully in as little as five minutes.
Glebar lists the automatic wheel balancing system as available with its TF-9DHD Infeed/Thrufeed Micro Grinder, GT-9AC Guidewire Grinding Machine and GT-610 Automated Infeed/Thrufeed Centerless Grinder.
