Flex Machine Tools Unveils FlexJet Waterjet System to Elevate Cutting Speed, Precision and Productivity!
Wednesday 10 December 2025, 3:11:08 PM
Flex Machine Tools has expanded its advanced cutting portfolio with the FlexJet series — a waterjet system engineered to deliver high-speed performance, precision cutting and extensive configuration flexibility for manufacturers handling complex applications. Built in the U.S. and designed with a user-centric approach, the FlexJet platform enables customers to select the pump, cutting head style and machine size best suited for their operational demands, making it adaptable for industries requiring reliable, high-accuracy material processing.
A standout in the lineup is the FlexJet FLX-1365, which features a powerful four-head cutting system aimed at maximizing throughput. By allowing multiple cutting heads to operate simultaneously, the system drastically reduces cutting time and lowers cost per part — a crucial advantage for shops handling high-volume or repetitive geometries. Standard configurations allow customers to choose between two or four cutting heads, with the flexibility to expand further depending on workflow or production scaling needs.
To maintain consistent performance across all active heads, the FlexJet FLX-1365 can be paired with higher-horsepower pumps, delivering the necessary pressure to support multihead cutting without compromising precision. Each cutting head incorporates its own dedicated mini hopper for uniform abrasive flow, ensuring consistent cut quality even during simultaneous operations. The ability to activate or deactivate individual heads adds to its versatility, allowing operators to tailor the cutting setup for different materials, part sizes or job priorities.
For ease of operation, the system features an auto-spacing function that allows rapid adjustment of the distance between cutting heads. This digitally controlled setup offers a maximum spacing of 48 inches and a minimum of 5.5 inches, enabling quick configuration changes while keeping the workflow efficient. Options span from conventional cutting heads to five-axis, tilter and multihead systems, allowing FlexJet users to address intricate geometries and heavy-duty applications with confidence.
Beyond its mechanical capabilities, the FlexJet platform is built around operator efficiency and seamless integration. Its design supports smoother workflow management, intuitive operation and faster job turnaround. Flex Machine Tools reinforces its customer-first approach by offering fully customized waterjet configurations tailored to specialized requirements, backed by robust service support and 24/7 remote response assistance.
With its high precision, multihead capabilities and flexible architecture, the FlexJet FLX-1365 demonstrates how modern waterjet systems can significantly enhance part throughput, reduce operational costs and expand cutting possibilities for manufacturers across metals, composites, plastics and specialty materials.
