Fairlane Products Expands Industrial Roller Portfolio with Advanced Material Options for Demanding Manufacturing Applications!
Fairlane Products has expanded its industrial roller lineup with a broader range of material options designed to meet the evolving demands of modern manufacturing, assembly, and material-handling environments. The enhanced portfolio provides manufacturers with greater flexibility in selecting rollers that match specific operating conditions, performance requirements, and application challenges, helping improve productivity, reliability, and material control across a wide variety of industrial processes.
Industrial rollers are essential components in manufacturing systems, conveyor operations, assembly lines, and material-handling equipment. Their performance directly impacts product movement, positioning accuracy, equipment efficiency, and maintenance requirements. Recognizing the need for application-specific solutions, Fairlane Products has introduced roller options manufactured from black neoprene, urethane, and white nitrile, each offering unique characteristics tailored to different industrial environments.
Black neoprene rollers are designed for applications where resistance to environmental exposure and harsh operating conditions is critical. The material provides excellent protection against flame, weather, gasoline, oils, ozone, and elevated temperatures, making it well suited for demanding industrial settings. These rollers can operate continuously at temperatures up to 200°F and withstand intermittent exposure up to 250°F, while maintaining performance at temperatures as low as -40°F. This versatility makes black neoprene an ideal choice for facilities that require dependable performance across a broad range of environmental conditions.
For applications that demand exceptional durability and load-bearing capability, Fairlane offers urethane rollers. Urethane is widely recognized for its superior abrasion resistance, high strength, excellent elongation properties, and overall toughness. These characteristics make it particularly suitable for high-cycle manufacturing operations where rollers experience continuous contact, friction, and heavy workloads. In addition to its mechanical advantages, urethane offers strong resistance to ozone and oxygen exposure, contributing to longer service life and reduced maintenance costs. The material supports continuous operating temperatures of up to 200°F and intermittent temperatures up to 250°F while remaining flexible at temperatures as low as -65°F.
White nitrile rollers provide another specialized solution for applications where resistance to gasoline, oil, alcohol, and abrasion is required. The material combines durability with chemical resistance, making it suitable for a variety of manufacturing and material-handling operations. White nitrile supports continuous operation up to 175°F and intermittent exposure up to 225°F while maintaining flexibility at temperatures down to -60°F. Its performance characteristics make it an attractive option for facilities seeking reliable operation in environments where chemical exposure is a concern.
To further increase application flexibility, Fairlane offers rollers in a wide range of durometers, from 20 to 95. A lower durometer provides a softer surface comparable to stiff foam rubber, ideal for handling delicate materials, while the higher end of the range offers hardness similar to a hockey puck, supporting applications that require greater rigidity and load-carrying capacity. This extensive selection allows manufacturers to match roller hardness to specific materials and operational requirements.
The product line includes shaft-drive rollers available in solid, finned, and DuraSoft configurations, with diameters ranging from 1.50 inches to 4.00 inches. Each shaft-drive model features a roller permanently bonded to a steel hub and secured to the shaft using dual locking set screws, ensuring reliable power transmission and long-term durability.
Solid rollers provide full-surface contact with workpieces, making them ideal for applications requiring smooth and consistent material handling. Finned rollers incorporate surface grooves that reduce contact area while allowing dirt, debris, moisture, and other contaminants to pass through, helping maintain efficient operation in challenging environments. DuraSoft rollers feature a unique design with teardrop-shaped openings that allow controlled flexing, enabling secure contact with workpieces while reducing the risk of damage to delicate materials.
A key advantage of the roller system is its ability to improve material movement control and positioning accuracy throughout manufacturing processes. By delivering efficient power transmission without relying on chains or belts, the rollers help reduce maintenance requirements while minimizing slippage and improving operational efficiency. This design contributes to smoother product flow, greater reliability, and increased productivity across a variety of applications.
Suitable for material handling, automated assembly systems, manufacturing operations, packaging lines, and conveyor applications, Fairlane’s expanded roller portfolio provides manufacturers with a versatile and reliable solution for improving process performance. With multiple material options, hardness configurations, and roller styles available, the company is helping industrial users optimize their equipment for greater durability, precision, and long-term productivity in increasingly demanding manufacturing environments.
