EXSYS Tool will feature a wide range of tooling systems, gearboxes and custom gear engineering from EXSYS/EPPINGER at the Canadian Manufacturing Technology Show, September 30-October 3, 2019, in Toronto, Ontario. Attendees will experience the cost-effective speed and flexibility of PRECI-FLEX® and DECO-FLEX®tooling systems as well as precision gear solutions.
The EPPINGER PRECI-FLEX modular toolholding system speeds turning center tooling changeovers and improves productivity with longer tool life. As part of the system, EXSYS will showcase double-collet PRECI-FLEX chucks for Mazak QUICK TURN and QTU Series Turning Centers with optional high-speed machine spindles. For small-part manufacturing, the DECO-FLEX tooling interface adds flexible precision and includes holders for all generations of Star CNC brand Swiss-style machines. EPPINGER gear solutions offer German-made precision in spiral bevel, planetary, planetary bevel, hypoid and cycloidal gearboxes, along with custom gear-making services.
The compact PRECI-FLEX modular toolholding system is the first of its kind on the market that utilizes the ER collet pocket and includes a single base holder with multiple tooling adapters. PRECI-FLEX’s conical and flat-face planar interface allows the use of either an adapter or a standard ER collet and enables collets, endmill holders, expanding collet chucks and shrink-fit tooling to be mounted on a single-base holder.
Double-collet PRECI-FLEX holders
Within the PRECI-FLEX modular tooling system, the revolutionary two-collet chuck delivers up to 10,000 rpm with a 1:1 ratio and 20 N-m of torque to boost productivity and achieve excellent surface finishes on machines with optional 10,000-rpm machine spindles, Y-axis functionality and standard BMT turrets. An EXSYS/EPPINGER Compensating Clutch with a floating coupling between turret drive motor tangs and toolholders automatically compensates for any misalignment to reduce vibration and tool chatter, producing longer tool life and better parts.
The high-accuracy DECO-FLEX tooling interface offers unmatched flexibility, precision and cost savings. Its minimal envelope dimensions make it ideal for use on turning and milling centers with limited working areas. The compact design ensures maximum torque transmission and rigidity for high machining accuracy, productivity and machine-tool efficiency.
DECO-FLEX holders for Star CNC brand Swiss-style machines
Along with mounting adapters, the DECO-FLEX interface includes holders mounted into and dedicated to Star CNC brand Swiss-style machines. These products enable high-volume shops to run multiple toolholders in a single tool position, reduce tooling changeover times significantly and increase tool rigidity for longer tool life on these machines. The DECO-FLEX system adapts to every Star machine model.
German-made EPPINGER gearboxes and custom gear-making services offer precision and flexibility for a wide variety of industries. BT (bevel torque) and BM (bevel maximum torque) spiral bevel gearboxes provide minimized tooth clearance and optimal transmission properties with precision axes and bearing seats as well as GLEASON bevel gears to withstand high loads. PE (planetary eco) and PP (planetary precision) planetary gearboxes combine low backlash, high efficiency, shock resistance and a high torque-to-weight ratio in a modular design that incorporates ground gears and precision gear components.
BP (bevel planetary) gearboxes pair BT and PE features in an innovative design with smooth-running components and constant backlash control. HT-type compact, robust hypoid gearboxes suit specific and highly dynamic applications, with a specially developed aluminum mono-block housing, high-precision bearing seats and an integrated input shank. High-transmission cycloidal gearboxes offer integrated support bearings and high-overload capacity for applications that demand the utmost stiffness, performance and efficiency.
For custom applications, EPPINGER applies more than 20 years of experience to develop and manufacture virtually any gear design, with crown gear diameters ranging from 0.4 mm to 330 mm, depending on transmission ratio.
