ESAB Introduces Rogue EMP 210 PRO to Simplify Multiprocess Welding!
Friday 28 November 2025, 8:11:36 AM
ESAB has launched the Rogue EMP 210 PRO, a compact, lightweight multiprocess welding power source engineered to simplify setup while delivering industrial-grade performance. Designed for users who want advanced capability in a highly portable unit, the Rogue EMP 210 PRO features an intuitive digital interface and smart Synergic Control that helps welders achieve optimized settings with minimal manual adjustments.
The system is built to streamline workflow across a range of welding tasks. With Synergic Control, the operator simply selects the wire type, diameter, and shielding gas, and the machine automatically adjusts parameters to maintain ideal performance across various material thicknesses. This automation removes the guesswork often associated with setting up a multiprocess welder. Once the initial selections are made, welders can fine-tune the heat by adjusting wire feed speed, while a trim control allows for precise arc refinement, ensuring consistent weld quality even in changing conditions.
Engineered for versatility, the Rogue EMP 210 PRO offers robust output across multiple welding processes. The unit delivers up to 210 A for MIG and TIG welding and up to 180 A for Stick welding at a 30 percent duty cycle, making it suitable for light fabrication, repair and maintenance, automotive projects, metal art, hobby applications, and jobsite work. Its multiprocess capability allows users to switch seamlessly between MIG, Stick, and TIG depending on project requirements, all within the same compact machine.
Weighing just 37.3 lb., the Rogue EMP 210 PRO is easy to transport and set up, whether in a workshop, garage, or field location. It operates on both 120 V and 230 V power sources and is generator-compatible, requiring 6 kW at 120 V and 10 kW at 230 V. This flexibility makes it a practical choice for mobile welders and small shops that may not have access to higher-voltage infrastructure.
The Rogue EMP 210 PRO includes a complete suite of advanced features across its welding modes. For MIG welding, operators can take advantage of spot and stitch timers, as well as adjustable gas pre-flow and post-flow to enhance weld starts and finishes. Stick welding functions include electrode-specific arc optimization, customizable Hot Start to reduce sticking on arc strikes, and adjustable Arc Force control, which is particularly useful for maintaining stability in tight spaces or out-of-position welds.
By combining portability with advanced digital controls, ESAB’s Rogue EMP 210 PRO offers a compelling blend of convenience, precision, and capability. It brings professional-level features to applications that demand both flexibility and ease of use, making it a valuable addition for welders across fabrication, maintenance, automotive, and creative metalworking environments.
