Engis ElectroMill Milling Tool Delivers High Stock Removal Rates and Precision Machining!
Friday 14 February 2025, 2:51:04 PM
At PMTS 2025, Engis Corp. is showcasing its ElectroMill diamond milling tool, a key addition to its Electrogrip superabrasive solutions. The ElectroMill is designed to produce high-quality, flat milled surfaces even when faced with challenges such as interrupted cuts or the need to machine multiple materials simultaneously.
Engineered for high-volume applications, the ElectroMill is ideal for machining high-strength alloys, stainless steel, ceramics, cast iron, fiberglass pipe, composites, and aluminum. It offers significant advantages over expensive, complex cutters traditionally used for these tasks.
The tool’s standout features include high stock removal rates, stress-free cutting action, and extended tool life, all of which contribute to reduced tooling costs and improved operational efficiency. The ElectroMill also benefits from optimized adapter mountings and milling cutting dimensions, ensuring precise and efficient machining.
When combined with high-pressure coolant, the ElectroMill is capable of achieving impressive flatness and surface finishes. For instance, when machining cast iron, the tool can deliver a flatness of up to 20 µm and surface finishes as smooth as 8 Ra over a continuous length of 25,000 inches. This level of precision helps reduce scrap and reworks, boosting productivity and enhancing the bottom line for manufacturers.
The ElectroMill is versatile and suitable for a wide range of industries, including marine, small-engine automotive, off-road, agriculture, aerospace, and defense, as well as machining ferrous, nonferrous, and exotic materials. With its ability to handle tough applications and deliver high-quality results at low tooling costs, the ElectroMill is a valuable tool for those seeking enhanced productivity and precision in their milling operations.
