Engineered for Excellence: Sugatsune Presents Smart Industrial Hardware!
Sugatsune, a global leader in industrial component hardware, has unveiled a new lineup of advanced products designed to enhance safety, functionality, and efficiency across diverse industrial environments. At the heart of these innovations is Motion Design Technology (MDT), Sugatsune’s proprietary platform that delivers precise, customizable mechanical motion. MDT enables engineers to tailor movement solutions to specific applications, resulting in smoother workflows, improved ergonomics, and safer equipment operation—particularly in environments where precision lid control is critical.
A standout in this lineup is the CJH handle, designed specifically for control boxes and industrial panels. Combining rugged durability with a clean, modern aesthetic, the CJH handle reflects Sugatsune’s focus on “beautility”—an intersection of beauty and utility. Its long, color-coded cap is available in multiple shades, including grey, yellow, black, orange, red, and blue, allowing intuitive operation and easy identification of zones or work areas. The handle supports both front and back screw mounting, ensuring flexible installation and reliable performance under demanding conditions.
For equipment stability on uneven surfaces, Sugatsune has introduced the ADPS and ADP stainless steel leveling glides. Available in corrosion-resistant 304 and 316 stainless steel, these glides are built to withstand challenging environments while delivering long-term reliability. Each unit features a hexagonal nut at the base for quick adjustment, a high load capacity, and robust construction, making them ideal for heavy-duty applications in industries ranging from food processing to industrial machinery.
Lid control is another area where Sugatsune’s innovations stand out. The HG S Swivel Torque Hinge, powered by MDT, offers smooth, controlled free-stop positioning at any angle. Its central hole enables clean cable management, while rigorous testing—20,000 open/close cycles—ensures long-lasting performance. This hinge is particularly suited to large control panels, HMI units, and heavy machinery, ensuring safe and reliable access during maintenance or operations.
Similarly, the HG PA202 Lift Assist Hinge demonstrates Sugatsune’s focus on simplifying user interaction with heavy equipment. Designed for top-opening lids, it integrates spring tension for lift assist, a built-in damper for soft-close performance, and an adjustable torque mechanism for fine-tuned operation. Its concealed mounting and hygienic design make it especially well-suited for food machinery applications, where safety and cleanliness are top priorities.
Beyond individual components, Sugatsune has developed a comprehensive range of torque hinge solutions built on its MDT philosophy. These include swivel torque hinges with integrated cable-routing, spring-assist hinges that reduce operator strain, and damper-based designs for smooth, quiet closure. Pivot and detachable hinges allow modular flexibility, while two-axis spring-assist hinges offer multi-directional movement in compact systems. Concealed torque hinges provide a seamless finish for premium designs, and stainless steel variants ensure resilience in harsh environments. Together, this range offers engineers unmatched flexibility in designing safe, ergonomic, and maintenance-friendly access solutions.
Also featured is the MC MS45 Sealed Magnetic Catch, a compact yet powerful component engineered for secure, quiet closures. Using a neodymium magnet for strength and a silicone rubber housing to reduce noise and wear, the catch is compatible with several counter plates and mounting options. While not intended for extreme chemical or moisture exposure, it is highly effective in standard industrial and commercial settings.
By combining precision engineering with practical usability, Sugatsune continues to reinforce its reputation for delivering hardware that balances safety, performance, and design. Its latest innovations reflect a commitment to enabling smoother operations and smarter solutions across global industries.
