Edge Technologies Revolutionizes Small-Diameter Bar Stock Feeding with FMB Turbo RS 2-20 Bar Feeder!
Sunday 30 March 2025, 10:26:47 AM
Edge Technologies is introducing an innovative solution to small-diameter bar stock applications at PMTS 2025 with the FMB Turbo RS 2-20 bar feeder. The FMB Turbo RS 2-20 is equipped with Revolutionary Sliding (RS) technology, a design that significantly enhances performance for Swiss lathe operators working with small-diameter bar stock. The system offers a more efficient and reliable bar feeding process, addressing common challenges such as vibration, cycle time, and precision.
A key feature of the FMB Turbo RS 2-20 is its sliding guide module design. This unique design ensures that the bar pusher and stock are fully supported and move seamlessly from within the feeder directly to the lathe spindle. Edge Technologies claims this is a first in the industry, offering a more reliable feeding solution that reduces the need for traditional accessories like telescopic noses, extended pushers, and Z-axis axial tracks, which were previously used to minimize the gap between the bar feeder and lathe.
By eliminating these components, the RS technology reduces vibration and allows for significantly higher rpm capabilities. This leads to smoother bar feeding and enhances machining performance, especially for applications that demand high precision and speed. With these improvements, the FMB Turbo RS 2-20 delivers better performance while reducing operational complications, ultimately benefiting manufacturers with more reliable and cost-effective operations.
In addition to its technological advancements, the FMB Turbo RS 2-20 offers space-saving advantages. Its design allows it to be installed closer to the back of the machine tool, making it more efficient in terms of floor space utilization. This feature is particularly useful for manufacturers with limited shop space. Despite its compact size, the Turbo RS 2-20 does not compromise on performance, making it an ideal choice for companies looking to optimize their shop layout while maintaining high-quality output.
This modular design makes the FMB Turbo RS 2-20 suitable for a wide range of applications, including non-guide bushing modes, long Z-axis strokes, working with challenging materials, and machining profiled stock. These features increase the machine’s versatility and ensure that manufacturers can address various machining challenges efficiently.
The FMB Turbo RS 2-20 is specifically designed to cater to the needs of Swiss lathe operators handling small-diameter bar stock. This innovative system addresses several pain points that are common in the industry, especially for operations that require high precision, speed, and consistent quality. With the improved support and reduced vibration offered by the RS technology, operators can expect significant improvements in key areas:
  • Faster Cycle Times: The Turbo RS 2-20 facilitates faster cycle times due to smoother bar feeding and higher rpm capabilities, resulting in shorter production times and improved throughput.
  • Improved Surface Finishes: The reduction in vibration and enhanced bar feeding capabilities lead to better surface finishes, a critical factor for high-quality machining.
  • Tighter Tolerances: The increased stability and performance enhancements ensure that parts are machined to tighter tolerances, which is especially important in industries like aerospace, automotive, and medical device manufacturing.
As Kevin Meehan, President of Edge Technologies, states, “This bar feeder addresses real challenges faced by Swiss lathe operators running applications with small-diameter bar stock.” The FMB Turbo RS 2-20 brings a much-needed solution to these challenges, combining faster cycle times, improved surface finishes, and tighter tolerances into one efficient machine.
Whether dealing with difficult materials, long Z-axis strokes, or the need for high accuracy, the FMB Turbo RS 2-20 is designed to meet the diverse needs of the small-diameter bar stock market. Edge Technologies has proven its commitment to innovation with this bar feeder, ensuring that manufacturers can improve their productivity and maintain high levels of quality in their machining processes.
With its Turbo RS 2-20, Edge Technologies has set a new standard for bar feeder technology, continuing to lead the way in helping manufacturers optimize their operations and achieve greater efficiency. The FMB Turbo RS 2-20 is a testament to the company’s dedication to solving industry challenges and advancing the future of machining technology.
