Dormer Pramet’s Force Drill Series Elevates Performance with Advanced Geometry, Coatings, and Flute Engineering!
Dormer Pramet, a global metal cutting tool manufacturer under the Sandvik Group, has introduced its latest Force lineup of solid carbide drills—an engineered solution designed to tackle some of the toughest drilling challenges in modern machining. By combining next-generation geometries, optimized coatings, and highly efficient flute designs, the Force series delivers smoother chip evacuation, extended tool life, and exceptional drilling accuracy across a wide range of materials and applications. Whether used in continuous production or demanding high-load environments, the new drills offer manufacturers a reliable, performance-driven approach to machining.
At the forefront of the lineup is Force X Generation 2, a versatile range that includes both through-coolant and solid drill options to accommodate various drilling depths. This series features an evolved flute geometry engineered to stabilize the cutting process and maintain consistent chip flow even in tougher materials. The addition of a TiAlN-top coating further enhances wear resistance and thermal stability, enabling reliable performance across ISO P (steel), ISO M (stainless steel), and ISO K (cast iron) workpiece groups. With improved tool rigidity and optimized coolant delivery, Force X Generation 2 helps manufacturers maintain high productivity while reducing downtime associated with tool wear or chip buildup.
For micro-drilling applications, Force Micro is designed to achieve remarkable accuracy in diameters ranging from 0.7 mm to 2.95 mm. These drills address the unique challenges of small-diameter machining, including tool deflection, heat generation, and breakage. The series ensures smooth, stable high-speed operation with long tool life, making it suitable for precision components found in electronics, medical devices, watchmaking, and aerospace instrumentation. By delivering consistent diameter control and clean hole quality, Force Micro supports processes where even the smallest machining imperfections can compromise final product performance.
Rounding out the lineup is Force Deep Hole Drills (Force DHD), engineered for drilling depths of up to 20×D with excellent positional accuracy. Deep-hole drilling introduces complex challenges related to chip evacuation, heat buildup, and axial stability. Force DHD addresses these concerns through internal coolant channels that optimize cooling at the cutting edge and maintain chip flow throughout the entire hole length. The drills are finished with a Nano-Tip multilayer coating, offering superior durability and thermal resistance under extreme conditions. These design features help prevent tool failure and improve overall process reliability, particularly in industries where deep, precise holes are essential—such as automotive, energy, moldmaking, and heavy engineering.
Across all three product families, Dormer Pramet’s Force Series combines innovation and practical engineering to deliver reliable, long-lasting tools capable of meeting evolving industry demands. With enhanced cutting performance, reduced tool wear, and more efficient material removal, the Force drills provide manufacturers with a competitive edge in precision, productivity, and process optimization.
