Davi’s iVision System Revolutionizes Plate Rolling with AI-Powered Precision!
Wednesday 22 January 2025, 5:41:19 PM
Davi Inc. has introduced the iVision laser radius measuring system, a cutting-edge solution that integrates artificial intelligence (AI) with its e-Power fully electric machines. Designed to streamline and automate the plate rolling process, the iVision system enhances precision, efficiency, and operational simplicity, making it possible for shops to run machines unmanned.
Key Features of the iVision System
  • AI Integration for Self-Correction: By combining AI with a specific algorithm, the iVision system enables real-time measurement and automatic self-correction through the machine’s CNC. This capability ensures unparalleled accuracy while significantly reducing the time required for the rolling process.
  • Laser Blade Technology: Unlike traditional single-point laser systems, the iVision utilizes a “laser blade” that scans a wider curved area, capturing thousands of data points simultaneously. This advanced scanning capability results in more precise measurements across radii of various sizes.
  • Dynamic Laser Head Movement: The laser head’s ability to move vertically and tilt ensures optimal positioning of the laser blade, allowing it to measure radii of any size accurately and efficiently.
  • Elimination of Templates: By removing the need for manual templates, the iVision system not only speeds up operations but also reduces dependency on highly skilled operators, making it an ideal solution for shops facing labor challenges.
Once the iVision system measures a radius, it transmits the data to the e-Power machine’s CNC, which makes the necessary side roll adjustments in real-time. This level of automation drastically minimizes the need for operator intervention and enhances the machine’s overall productivity.
For shops using machines without CNC controls, Davi offers the iRadius version. This variant provides a digital readout of measurements, enabling operators to manually adjust the machine settings as needed. Both systems eliminate the need for operators to manually measure radii at the front of the machine or inside large parts, improving safety and reducing downtime.
The iRadius unit is fully retrofittable to existing machines, making it a valuable addition for shops handling extremely large parts that traditionally require cumbersome manual measurements. By integrating these systems, manufacturers can optimize their workflows while ensuring superior results.
Davi’s iVision and iRadius systems exemplify the next generation of plate rolling technology. With enhanced automation, reduced operator dependency, and significant time savings, these solutions empower manufacturers to achieve higher productivity and precision while meeting the evolving demands of modern fabrication.
