Chevalier CNC Slant-Bed Lathe Automates Small-Part Production with Advanced Features!
Thursday 3 July 2025, 6:38:33 PM
Chevalier Machinery Inc. has introduced the FCL-130RP, a high-precision CNC lathe designed specifically for small-part automation. This new model is engineered to meet the growing demand for space-efficient, high-speed turning solutions across various industries, providing a reliable and compact solution for production lines with limited space.
At a machine length of 70.9″ (1802 mm), the FCL-130RP is designed to maximize floor space usage, making it ideal for tightly packed production lines or flexible plant layouts where space optimization is key. The lathe features a 30-degree slant bed, which not only provides a rigid and stable performance but also improves chip removal and enhances long-term machining stability. This ensures that the machine can maintain consistent, high-quality production even during extended operations.
One of the standout features of the FCL-130RP is its integration with a two-axis gantry robot, enabling fully automated part handling. This automation significantly reduces cycle times, with workpiece swapping occurring in just 5.5 seconds. The use of parallel-type grippers allows for simultaneous loading and unloading operations, further optimizing efficiency. The intuitive setup process requires only three input values, making it easy to handle diverse workpieces. Additionally, the integrated workpiece counter helps track job progress accurately, ensuring precise job management throughout the production process.
The FCL-130RP is capable of handling small to medium-sized components with specifications including a maximum cutting diameter of 9.29″ (236 mm) and a maximum cutting length of 9.17″ (233 mm). The lathe supports parts up to 3.15″ (80 mm) in diameter, 3.94″ (100 mm) in length, and 6.6 lbs (3 kg) in weight, offering great versatility for a wide range of applications. Whether for producing complex components or simple parts, the FCL-130RP can handle a variety of machining tasks, making it suitable for industries such as automotive, electronics, and medical device manufacturing.
To ensure smooth, precise cutting at high speeds, the lathe is equipped with roller-type linear guideways and high-precision 3.15″- (80-mm) diameter spindle bearings. These components allow the machine to operate smoothly and accurately, with minimal vibration even at high spindle speeds of up to 6,000 rpm. The spindle motor provides 5/7.4 hp (3.7/5.5 kW) power, supporting consistent performance during demanding operations.
The machine also boasts an intuitive graphical user interface for its robotic system, with controller options from FANUC and Mitsubishi. These controllers offer features such as 3D machining simulation and manual guide and ShopTurn options, making it easier for operators to set up and control the system. In addition to its standard equipment, which includes a 6″ hydraulic chuck, toolholders, soft and hard jaws, and a moveable coolant tank, the FCL-130RP also offers optional accessories to enhance workflow integration. These include an automatic door, toolsetter, parts catcher, and oil-mist collector, allowing for increased functionality and improved overall performance.
The FCL-130RP represents a significant advancement in automated turning solutions, offering manufacturers an efficient, high-speed, and space-saving CNC lathe that meets the demands of modern production environments. With its combination of precision engineering, automation capabilities, and versatile features, the FCL-130RP is poised to support the production of high-quality, small to medium-sized components with greater efficiency and reliability.
