Ceratizit AluLine Micro Milling Cutters: Precision for Micromachining!
Friday 7 March 2025, 1:18:44 PM
At PMTS 2025, Ceratizit will showcase its AluLine – Micro milling cutters, designed for high-precision machining of miniature parts. These cutters are optimized for small workpieces that demand high-tolerance machining, featuring a shrinkable 4-mm shank and cutting diameters ranging from 0.2 to 3.0 mm, with projection lengths from 3 × D to 15 × D. With a thin diamond-like carbon (DLC) coating, AluLine – Micro milling cutters offer machinists pinpoint accuracy, achieving tolerances of 3 µm at a 0.2-mm diameter.
The 4-mm shank is compatible with shrink-fit toolholders, ensuring optimal concentricity and the highest contour quality for small components. Designed with an ultra-fine grain substrate, these cutters excel when working with abrasive aluminum alloys. The specialized polishing grind helps mitigate sticky chip formations and built-up edge issues, ensuring smoother chip flow and enhancing tool performance. Additionally, the DLC coating extends tool life and improves chip removal from the cutting zone, making the AluLine – Micro milling cutters an excellent choice for machining small, complex parts with precision and efficiency.
