Carmex Precision Tools Unveils FSH Solid Carbide Thread Mills at PMTS 2025!
Monday 17 March 2025, 3:22:23 PM
Carmex Precision Tools is showcasing its FSH solid carbide thread mills at PMTS 2025, designed for faster and more accurate thread milling in hard and heat-resistant materials up to 65 HRC. Constructed from ultra-fine-grain carbide, these thread mills feature a physical vapor deposition (PVD) multilayer Nano coating that enhances their durability and performance.
The FSH thread mills come in a range of sizes, from M2 × 0.4 through M16 × 1.75 mm pitch, with thread forms spanning from 2-56 through ¾ 10UN. These mills offer five to seven flutes, depending on the size, and are equipped with a left-handed helix configuration, which reduces deflection and results in smoother, faster, and more accurate cuts. Suitable for both conventional machining and Swiss-style applications, the FSH series is engineered to provide optimal efficiency when machining tough materials.
