Behringer Saws Showcasing Advanced Cutting Solutions at EASTEC 2025!
Tuesday 13 May 2025, 4:31:02 PM
Behringer Saws Inc., a leader in high-performance bandsawing machines, circular cold saws, and structural fabricating equipment, is set to showcase its latest innovations at EASTEC 2025, held from May 13-15 in West Springfield, Massachusetts. Visitors to Booth #2004 will have the opportunity to experience the capabilities of two flagship machines: the HBE321A Dynamic horizontal bandsaw and the VMS 370 cold saw. Both machines are engineered to deliver precision, efficiency, and versatility for a wide range of metal cutting applications.
The HBE321A Dynamic automatic bandsaw is designed to provide economical and high-performance cuts across various industries, including steel trade sectors. With its robust construction, it is capable of cutting a wide range of materials, from profiles and tubes to solid metal, while maintaining tight tolerances and work protection. The saw’s cast iron band guiding parts provide vibration damping at the cutting edge, which extends tool life and enhances cutting precision.
Equipped with a servo downfeed system driven by a ball screw and servo motor, the HBE321A Dynamic offers shorter idle times and precise saw feeds, resulting in higher cutting performance and longer band life. The machine features sensitive BEHRINGER cutting pressure control, which automatically adapts the saw feed to varying material cross-sections, optimizing the cutting performance for tubes and profiles. Additional features include:
  • Automatic guide arm for consistent sawing results
  • Electrically driven chip brush for tool-free maintenance
  • Double clamping vice that ensures reliable clamping for both single cuts and bundles
The VMS 370 cold saw series is renowned for its simple operation, robust construction, and precise cutting capabilities. With over 250,000 units sold, it remains a trusted solution for cutting solid materials, tubes, and profiles. The in-house produced worm gear unit with Eisele shock-absorbing technology ensures low-vibration saw operation, which extends blade life and machine service life.
Designed for flexibility and space efficiency, the VMS 370 features:
  • User-friendly miter adjustments with fixed stops
  • Vibration-damping cast iron components in the sturdy machine base
  • Saw feed controlled by a safety snap-in lever for precise travel settings
An optional micro spray lubrication system ensures optimal cutting conditions by moistening the saw blade with cutting oil, promoting long tool life and maintaining a clean working environment.
Attendees at EASTEC 2025 are invited to explore these cutting-edge machines and engage with Behringer’s expert team. The company remains committed to delivering innovative, precise, and reliable sawing solutions that meet the evolving demands of manufacturers. Behringer’s dedication to customer service and industry-leading technology continues to set high standards in the sawing technology sector.
At EASTEC 2025, Behringer Saws will showcase its HBE321A Dynamic horizontal bandsaw and VMS 370 cold saw, offering manufacturers advanced tools for precision cutting, higher productivity, and cost savings. With a strong focus on innovation and customer satisfaction, Behringer continues to lead the way in providing versatile cutting solutions for industries such as metalworking, construction, and fabrication.
