Automotive metal components: Mevis invests in Metrios measuring technology.
Mevis supplies major multinational market leaders, mainly in the automotive industry, which represents 70% of the company’s turnover, followed by the electromechanical, household appliances, and electrotechnical sectors. The company’s main products include bent and printed wire parts, welded parts, assembled parts, strip springs, compression springs, and tubular parts.
“To measure sheared and bent parts and CNC production, we need the right instruments. These are profile projectors, where you place a part, and with a specific light you can define the shape and take the measurements.”
8 processing plants.
The group has an extensive and advanced machine park including spring coiling machines, bending machines, torsion spring winding machines, automatic presses, welding plants, and of course, measuring machines. The company invests heavily in latest generation technology to keep a competitive edge in terms of quality, costs, and development times.
Traditional tools could no longer keep up with demanding production rates. Quality is a major pillar in the company’s business philosophy. It is a necessary aspect of every phase in the production process but requires particular attention in terms of cost containment.
Bruno Sartori, Head of Quality Control, explains how traditional measuring instruments were no longer capable of checking hundreds of parts: “We used a classic cranked profile projector; we had to turn the dial to see the angles and to align the part. The results were highly subjective and the process was essentially very slow.”
“Our operators had to perform many measurements to guarantee the required level of quality. This led to a considerable waste of time – up to 20 minutes were lost per code.”
The introduction of 4 Metrios measuring machines in Italy and Slovakia.
“These machines measure all the bent and sheared small parts. And that’s not all, we manage to measure all the parts that can fit within the field of view, even up to 20 at a time. Take torsion springs, for instance, in just a few seconds we can detect the angles, length of the stems, diameters.”
There was an evident increase in productivity after improving the inspection phase.
Mevis operators can finally carry out inspections independently and are enthusiastic about using a high-tech tool in production.
“Each operator on the shop floor has an ID badge and calls up the program via barcode. All the measurements taken arrive directly to the server, ready to be processed. Previously everything had to be written by hand!”
“If before, an operator could monitor just 4 plants and take the measurements, today that same person can control the quality of six or seven plants. Our work supports production because it’s important for the operators to monitor the machine and understand production trends.”
Sometimes, like we see here, the part might have multiple views.
“Another important advantage is that, with a manual projector you position one part at a time. But on the Metrios stage, you can measure multiple parts at the same time.”
MEVIS has 4 Metrios machines installed in its plants.
