Allied Machine and Engineering Drill Enhances Tool Life and Performance!
Friday 14 March 2025, 3:02:42 PM
Allied Machine and Engineering is showcasing its T-A Pro replaceable insert drill, designed to offer extended tool life and improved performance for a range of industrial applications. With a diameter range from 0.3739″ to 1.8820″ (9.50-47.80 mm), the T-A Pro combines the consistency of a spade drill with the penetration rates of a high-performance drill, making it a reliable solution for precision machining.
The T-A Pro line is available in various materials, including steel (P), cast iron (K), nonferrous (N), stainless steel (M), and high-speed steel (X), allowing users to choose the right substrate for their specific applications. The drill’s insert point design helps center and guide the tool through the cut, ensuring well-positioned holes in shorter applications, while its robust construction allows for greater drill depths and longer holes.
Built for durability, the T-A Pro is engineered to provide extended tool life, even in tough applications, by maintaining stability and creating high-quality holes consistently. The increased flute area enhances chip evacuation, while the strong cross-sectional core supports stable drilling operations. The coolant outlet configuration further boosts performance by improving coolant flow, lubricating the cutting edge, minimizing heat buildup, and reducing the risk of built-up edges. This makes the T-A Pro an excellent choice for precision drilling in demanding environments.
