XB SERIES – Multi functional turning tools
Friday 5 December 2025, 3:11:23 PM
Introducing the XB Series: High-Performance Indexable Turning Tools for Superior Machining
Mitsubishi Materials proudly unveils the XB Series Indexable Turning Tools – a groundbreaking solution engineered for versatility, precision, and productivity across a wide range of machining operations. Designed with a highly rigid six-sided secure restraint system, the XB Series ensures optimal clamping and stability. This significantly reducing chatter and vibration even under demanding machining conditions.
Suitable for internal and external machining, grooving, chamfering, threading and side-face grooving  operations, the XB Series offers a single-holder solution for multiple applications. The integrated internal coolant design, available in both carbide and steel shanks, ensures efficient chip removal, superior cooling that contribute to extended tool life. This feature not only enhances machining stability but also supports burr-free performance, particularly in internal cutting operations.
The XB Series demonstrates a remarkable increase in productivity. When replacing conventional tapping with the XB threading insert, users can expect up to 76% more components machined, along with reduced material waste and shorter cycle times.
Compatible with SLV sleeve holders, the tool also supports high-pressure coolant delivery, further boosting operational reliability. The high-pressure coolant also ensures that chip evacuation, especially  in small  diameter bores is excellent and brings an enhanced level of process security.
Engineered to minimize tool changes and maximize output, the XB Series is the ideal choice for manufacturers seeking efficiency without compromise. With high-quality cutting edges and excellent sharpness, a full range of tools for a variety of applications are available. From aerospace through to the automotive and general metal cutting industries, it sets a new standards for versatility and reliability.
