MATSUURA WILL SHOWCASE INNOVATION IN ACTION AT IMTS 2024
Tuesday 11 June 2024, 11:31:48 AM
EXPERIENCE THE FUTURE OF PRODUCTIVITY
Meet even the most formidable production demands with Matsuura. Enabling unmanned operation, our machining centers improve productivity, reduce labor costs, and maintain precision—ultimately delivering an exceptional ROI. See innovation in action at IMTS, and discover how Matsuura can help your business thrive.
MACHINES IN ACTION AT IMTS
Around-the-clock automation, adaptable pallets, and other advanced features ensure that Matsuura machining centers deliver exceptional quality and unmatched performance in every task. Explore the innovative capabilities of the LF-160 PC42MAM72-42VMX-330 PC10MX-520 PC4, and H.PLUS-405 PC6 machining centers, on display at IMTS 2024.
WITNESS A BREAKTHROUGH IN 3D PRINTING
As the world’s first hybrid metal 3D printer, the LUMEX Avance-25 gets you to market faster with a finished part produced in the correct molding resin and with production-like processes. The LUMEX Avance-25 is the key to true digital manufacturing, reduced cycle times, lower tooling costs, and simplified machine set up and part handling.
Matsuura will feature the following high precision machines at IMTS 2024:
LF-160
5 AXIS VERTICAL | Machining Center
HIGH SPEED | SMALL FOOTPRINT | AUTOMATED OPERATION
The LF-160 delivers high accuracy in a compact footprint. Its high-speed spindle and multiple pallet options allow for high production and extended life of small diameter tools. The LF-160 features the highest number of pallets in a 5-axis machine and an ultra-low vibration spindle, ensuring expert precision and exceptionally high accuracy with every run. It’s the ideal machine for small or delicate parts, such as medical devices and implants.
Specs: 31iB control, 46K HSK-E40 spindle, 338 ATC, PC42
MAM72-42V PC32
AUTOMATED OPERATION | PALLETIZED VERSATILITY | SPEED & PRECISION
With high accuracy, high repeatability, and the capability to run unmanned for extended periods, the MAM72-42V is designed to meet production demands and maximize labor efficiency.
The efficient, powerful, and versatile MAM72-42V features a tailstock option and extra support for long workpieces and tall tombstone fixtures. Its pallet and tool options are compatible with the MAM72-35V, and, like other MAM series machines, it can support continuous production for up to 72 hours.
Specs: 31iB MiOS4 control, 20K Oil-Air Spindle, 330 ATC, PC32
MX-330 PC10
COST EFFECTIVE | REPEATABILITY | COMPACT SIZE
The MX-330 PC10 makes efficient, cost-effective production possible with a minimal footprint, large pallet pool, and unmanned automation system.
The MX-330 PC10 features a compact floor plan with a large work envelope and high rigidity. Its pallets are compatible with the MAM72-35V and MX-420 PC10, making it easy to transfer work between platforms. Maximize manufacturing floor space, reduce training time, and improve productivity.
Specs: 31iB MiOS4 control, 20K Oil-Air Spindle, 90 Tool, PC10
MX-520 PC4
COST EFFECTIVE | HIGH PRECISION | COMPACT SIZE
Get more done in less space with the MX-520 PC4. Its compact size, ergonomic design, and compatible capabilities lead to increased production with less effort, shorter training times, and assured accuracy.
The MX-520 PC4 features high rigidity and repeatability, and Matsuura’s extended unmanned operation. With a minimal footprint and the unique ability to swap pallets with MAM72-52V, it’s an ultra-efficient use of space.
Specs: 31iB MiOS4 control, 20K Oil-Air Spindle, 90 Tool, PC4
H.Plus-405 PC6
PALLETIZED | ADAPTABLE AUTOMATION | RELIABLE PERFORMANCE
With the H.Plus-405, efficiency couldn’t be easier. Swap tools and pallets as production needs change and achieve higher productivity with around-the-clock automation
The H.Plus-405 features the Matsuura-made direct drive 4-axis table, Y-axis stroke extension, and compatibility with FASTEMS systems. Uniquely versatile, it delivers long periods of reliable operation, high accuracy, and efficient production.
Specs: 31iB control, 20K Oil-Air Spindle, 330 ATC, PC6
LUMEX Avance-25
REDUCED EDM & POLISHING | FAST TIME TO MARKET | LIGHTS OUT MANUFACTURING
The LUMEX Avance-25 metal laser sintering hybrid milling machine is a powder bed metal AM platform with subtractive machining capability. The machine combines selective laser sintering (SLS) along with high-speed milling (HSM) commonly called Hybrid AM.
Specs: 45k min-1 built-in #20 dual contact, grease lub spindle, 20 tools, u-axis travel 300mm spec (max build parts weight 150kg).
FIND US AT BOOTH #338630 IN THE SOUTH BUILDING, LEVEL 3. More  at: https://www.matsuurausa.com/imts.
Original source Matsuura USA
