The Unika is a high speed milling centre with a movable column. This machine has an impressive feed rate of 60 M/min and the linear axes are water cooled to provide a constant temperature controlled machine structure for producing high precision parts. The working area can be equipped with an index table, tailstock and automatic fixtures to provide total flexibility for various work holding applications.
This impressive machine comes in three different variations the BLISK, BLADE & MECH, each with variations in their specifications but offering such high quality standards for any manufacturer.
The BLADE & MECH models both have a rotary table with a torque motor for milling and turning which is controlled by the numerical control, the only slight variation is that the MECH has a bigger work surface of Ø 400 x 600 mm. The BLISK has a rotary and tilting table with torque motors for 5-axis machining, perfect for aerospace blisk components and has a work surface of up to Ø 400 x 800 mm.
This machine is perfect for the aerospace, power generation and automotive industries and Gruppo Parpas has many successful installations within this, and other industries where a high degree of accuracy and complexity are required. To view the brochure please click here – UNIKA Brochure
Gruppo Parpas are a well established company and a major manufacturer of ‘medium to large’ range of sophisticated machine tools and also suppliers of gantry mills, horizontal boring machines, bed-type mills and 5-axis machines, many using linear drive technology to achieve high speeds.
For more information on the Gruppo Parpas’ range of machines visit www.leadercnc.co.uk or alternatively follow us on our social media channels for regular updates.
