Gruppo Parpas’ High Quality Machine Tool Range for Aerospace & Energy Sectors
Monday 14 May 2018, 12:00:00 AM
Gruppo Parpas, one of Leader CNC Technologies newest principal, has devoted and manufactured some of its machine tools for the aerospace and energy industries and other industries. To make sure customers are fully satisfied fully trained engineers are assigned to test and evaluate the product range to make sure that machining is at its best for the best quality precision.
The range of machine tools designated to aerospace and energy is varied, they include the Unika, Diamond, HSC, Shark and finally the Roller.
The Unika, is a high speed milling machine with movable column. The machine allows an impressive feed rate of 60 M/min and movements of the linear axes are water cooled to allow the temperature controlled and constant when producing parts of high precision. The working area can be installed with an index table, tailstock and clamping piece systems.
The Diamond gantry style machining centre has 3 or 5 axis for high speed moulds/dies machining as well as aerospace parts. The machine offers a monobloc structure with a gantry moving saddle and stationary workpiece.
HSC – Linear is another high speed milling machine and known for its very compact line and for the fixed bed and mobile column formation. The machining centre uses linear motor drives to achieve rapid rates of 60M/min and also offering a combined choice of various head attachments, integral rotary tables or trunnions. The HSC is ideal to manufacture complex components within the aerospace and energy industries. If different applications are applicable, the HSC can be equipped with twin spindles for mass production or specially configured for parts such as turbine blades.
The Shark is a fixed bed moving column machining centre and has high torque, performance and speed. The ram can be fitted with a number of head attachments and the table is up to an impressive 5.5M in length is available with a rotary table or a central partition for pendulum milling. The machine is perfect for all sectors with low friction rates and swift tool changing which allows less lead time, reducing production costs.
Finally, the fixed gantry Roller offers maximum flexibility through a wide variety of table configurations and spindle heads. The square or round continuous rotary table, capable of carrying loads up to 3500kg, can also be supplied for turning applications up to 600rpm. The continuous universal head is fitted with a high torque 18000rpm spindle or other spindle options are available.
