BALANCE SYSTEMS S.R.L PRODUCTS FROM LEADER CHUCK INTERNATIONAL
Tuesday 24 January 2023, 10:12:55 AM
Absolute Balancer: 1 and 2 Plane Automatic Balancing Devices for Grinding Machines
The exclusive range of ABSOLUTE BALANCER® heads clearly represents the quality that Balance Systems strive to uphold within the automatic balancing technology. Available in all configurations for one and two plane balancing, the ABSOLUTE BALANCER® heads ensure unprecedented performances both in terms of execution speed and final accuracy and are managed via contactless control (NoLink), using the VM25 modular multifunction unit.
Features
  • An exclusive Balance Systems design with moment-free architecture
  • Designed in a wide range of diameters and shapes for built-in spindle mounting, starting from diameter 28mm
  • An embedded rotational speed sensor
  • Operating rotation speeds up to 25.000 rpm
  • Residual unbalance is achievable in at least 10 times the fewer tries as traditional solutions on 1 and 2 plane
  • Deterministic balancing time
  • Automatic neutral cycle (weights at 180°)
  • Acoustic emission sensor (AE) can be integrated (optional)
