ITC Publishes Latest Product Catalogue
Friday 1 April 2022, 7:26:48 PM
Industrial Tooling Corporation (ITC) has now published the latest edition of its annual product catalogue. Now reaching its sixteenth edition, the new catalogue is jam-packed with new product developments from the Tamworth based cutting tool manufacturer.
As a UK manufacturer of innovative cutting tools, the much-anticipated Issue 16 catalogue is crammed with high quality technically advanced cutting tools that include ingenious new milling, drilling, reaming, threading, thread milling and specialist milling lines. The latest edition of the catalogue incorporates ITC’s updated pricing structure for 2022 as well as having extensive sections that cover cutting tools for machining aluminium, steel, heat resistant alloys and exotic materials as well as glass and carbon fibre composite materials. The information in the latest edition also highlights the unparalleled range of trochoidal and barrel end mills as well as the re-grind service.
With disruption and delays to UK supply chains due to both Covid and Brexit, most cutting tool manufacturers cannot maintain their previous leads-times and supply chain commitments. As a UK manufacturer with its standard and specialist product lines manufactured in the Midlands, ITC is proud to demonstrate its ability to provide service and quality levels beyond that of its competitors. In the Issue 16 catalogue, ITC highlights its diverse range of UK produced bespoke trochoidal and barrel tools as well as its re-grinding service centre. The new publication also has a section on ITC’s UK manufactured micro tooling line that introduces micro end mills from 0.2mm to 3mm diameter with micro ball end mill tools available from 0.3mm diameter.
To view a copy of the latest ITC Issue 16 product catalogue, please visit www.itc-ltd.co.uk or alternately, you can download the edition athttps://www.itc-ltd.co.uk/wp-content/uploads/2022/01/ITC-Product-Catalogue-Issue-16.pdf If you would like to receive a printed edition of the catalogue, please contact your local ITC representative or call the Tamworth office on: 01827 304500.
