Programming simplicity will be Hurco’s theme for Southern Manufacturing 2026
Thursday 27 November 2025, 4:19:27 PM
Hurco will be demonstrating the latest software developments available on the Max5 control at Southern Manufacturing & Electronics 2026. They include a Solid Model Import option, which enables conversational programs to be created directly from an STP file. Similarly, 3D DXF files may be imported and worked on seamlessly.
The 19-inch colour touch-screen control has always been popular due to the ease with which a first-off part can be programmed. Simple conversational prompts guide the user through the stages of the program, taking the load off the manufacturer’s CAM station. Offline-generated NC code can be added into the program using an NC Merge function. Live on-line help is available at the control.
Hurco will exhibit two of their most popular machines. One is the versatile Hurco VM10i machining centre with a working volume of 660 x 406 x 508 mm. Fitting into a compact space, the machine will impress visitors with its ability to offer true machining centre performance. Steel cutting demonstrations will take place throughout the duration of the show.
Sharing equal prominence on the stand will be a Hurco TM6i 2-axis CNC lathe. It is able to turn parts up to 316 mm in diameter, 340 mm long, and is well suited to bar work up to 45 mm diameter. The performance of this compact, accurate turning machine is complemented by the Max5 control.
Simple, easy-to-follow graphics guide the user through all operations and tooling selection. The new XP model enhancements mean that concurrent programming, improved graphics and roller guideways are now standard features. The slant-bed lathe is supplied with a 6-inch hydraulic three-jaw chuck, parts catcher and swarf conveyor.
