Hainbuch Set to Grip The Crowds at Southern Manufacturing 2019
Tuesday 27 November 2018, 12:00:00 AM
On Stand P230 at Southern Manufacturing 2019, workholding innovators Hainbuch will be introducing a host of exciting technologies to show visitors at the Farnborough event that takes place from the 5th to 7th February. With flexibility, minimal interference contour and precision levels all being key factors for the modern workholding solution, Hainbuch will be demonstrating these attributes in its new range of TOPlus and SPANNTOP mini chucks.
Making an appearance at the show will be the new modular mini chucks from Hainbuch that will bring a new era of compatibility and flexibility for customers. The leading workholding specialist has also developed the SPANNTOP mini chuck to make it compatible with an adapter ring in order to use the new modular system. The exciting MANDO Adapt mandrel and the corresponding jaw module already work perfectly with the new SPANNTOP mini, meaning complete autonomy for your small component clamping needs.
Unlike the SPANNTOP mini chuck, the configuration for the TOPlus system is a little different. Whereas the SPANNTOP uses an adaptor ring, the TOPlus system has a ring of attachment holes to secure the market leading jaw module. At the Southern Show, Hainbuch will be demonstrating the innovative new MANDO Adapt series of adapters that will also work in harmony with the popular TOPlus system.
Additional innovations on show will include the Manok and Hydrok hydraulically actuated stationary chuck. The choice product for 5-axis machining or efficient multiple clamping, the Hydrok Intelligent modular system offers greater possibilities that ever before. Depending on size, the Hydrok can be used with all clamping device adaptations, such as the MANDO Adapt mandrel-in-clamping device or with the jaw module. Thus, in the future, you can also rely completely on the intelligent Hainbuch modular system, even for your stationary clamping device.
The Hydrok incorporates typical Hainbuch features such as user friendly set-up, parallel clamping, optimal power conversion, extreme rigidity and superior holding power. With a repeatability of less than 0.01mm possible, the Hydrok is ideal for 5-sided machining as well as flexible clamping scenarios such as mandrel clamping or jaw clamping thanks to the HAINBUCH modular system.
Another key innovation that will be of interest to visitors will be the impressive new TestIT clamping force gauge system that has been developed in conjunction with Siemens. The new software system is available on a data carrier for installation on Siemens CNC controllers. This now means that a separate laptop is not needed and manufacturing with ‘theoretical clamping forces’ is also a thing of the past. Thanks to TestIT, the operator always knows what clamping forces exist and where.
Making a Southern Manufacturing show debut will be the new Magnet Module. This exciting new concept has been developed for the processing of complicated components or thin walled parts. Designed and developed with Neodymium 'Super Strength' magnets, the new Magnet Modules are compatible with standard Hainbuch workholding chucks, such as the extremely popular TOPlus and SPANNTOP systems. With just a single screw that activates the magnet, the new Magnet Module provides ease of use and very fast clamp and un-clamping times. Incorporating a magnet on/off operation screw and super strength magnets that provide a maximum holding force of up to 140 N/cm², the Hainbuch Magnet Module is an extremely flexible and robust system. For more details on these innovations and much more, please contact your local Hainbuch representative or come and visit us on Stand P230 at Southern Manufacturing 2019 from the 5th to 7th February at FIVE Farnborough.
