ATOS Q: The new compact performer
Tuesday 6 April 2021, 4:49:21 PM
GOM has now introduced the new ATOS Q, the most compact of its optical 3D measuring systems. The ATOS Q is a powerful 3D scanner for complex inspection tasks. The light and flexible system is equipped with interchangeable lenses for small to medium-sized parts and comes with the latest GOM software.
GOM launched the newest member of the ATOS col-lection- ATOS Q on the 24th June via an online webinar where the reliability and versatility of this portable, lightweight system was explained.
The ATOS Q incorporates proven ATOS technology features such as the Triple Scan Principle, the Blue Light Equalizer and precise calibration as a self-monitoring system with active temperature management. The fringe projection required for precise measurements is performed at high speed and the integrated fibre optic cables enable rapid data transmission and high data throughput. Like other ATOS 3D scanners, the compact system meets high metrological requirements and is provided with the latest inspection software, GOM In-spect Suite.
With its dimensions of 340mm x 240mm x 83mm and a weight of less than 4kg, the ATOS Q is small, mobile and flexible. With five different, interchangeable lenses, the ATOS Q achieves measuring areas from 100 x 70mm2 to 500 x 370mm2. It covers a wide range of components in various industries.
