GER Máquinas Herramienta, a leading manufacturer in Spain, has announced the launch of its GER CU-CNC series, a versatile universal cylindrical grinder engineered for multi-operation production environments. Designed for precision and reliability, the series is set to enhance grinding capabilities for manufacturers requiring both external and internal processes.
The CU-CNC is built for versatility, accommodating complex applications with a single setup. It supports external, internal, and face grinding, making it an ideal solution for intricate component requirements. The machine’s large capacity can handle components up to 2,000 mm in length, 450 mm in diameter, and 500 kg in weight. This adaptability makes it suitable for a wide range of industrial applications.
Central to the CU-CNC’s performance is the integration of the Advanced FANUC 0i-TF CNC system, which ensures precision motion control, stability, and ease of use. Users benefit from multi-wheel versatility, supported by multiple external wheels, internal grinding spindles, and B-axis indexing. This configuration allows for the processing of compound geometries and multi-operation processes.
The GER CU-CNC features a rigid machine bed constructed from stabilized, heavily ribbed perlitic cast-iron, providing thermal stability and vibration damping. This ensures long-term geometric accuracy, a critical factor in maintaining the integrity of the grinding process.
For enhanced efficiency, the series offers optional equipment, including internal grinding spindles, automatic loading and unloading systems, in-process diameter measurement systems, and C-axis functionality for non-circular or spiral grinding applications.
Supported in the UK by DTS (UK) Ltd, the GER CU-CNC provides the flexibility of a universal grinder coupled with the high standards of precision engineering GER is renowned for. For those looking to enhance their grinding processes, DTS offers specification support to tailor the CU-CNC to individual operational needs.
Read this post on LinkedIn
