New IBARMIA Z Extreme 3-Axis Revolutionizes Precision Machining
Tuesday 13 January 2026, 7:24:34 PM
The IBARMIA Z Extreme 3-Axis machining center is setting new benchmarks in the manufacturing sector with its unparalleled precision and stability. Designed specifically for high-accuracy applications, this innovative machine caters to the demanding needs of aerospace, energy, and advanced engineering industries.
The machine features a moving-column design, ensuring exceptional rigidity and flexibility. It facilitates high-precision machining of large and complex components, making it an ideal choice for manufacturers focusing on accuracy, stability, and repeatability.
One of the standout features of the IBARMIA Z Extreme is its powerful spindle options. The machining center can be equipped with an electrospindle capable of reaching up to 12,000 rpm, with power up to 84 kW and torque reaching 452 Nm, depending on configuration. Additionally, the machine boasts an extensive working envelope, with X-axis travel up to 12,000 mm, and Y-axis options ranging from 800 to 1100 mm. The Z-axis offers travel up to 1100 mm, optionally extendable to 1300 mm.
The machining center’s standard tool magazine has a 40-tool capacity, expandable up to 134 tools. With excellent thermal stability, the machine maintains accuracy even during extended machining cycles. Manufacturers can choose from advanced CNC control systems like Siemens, Heidenhain, or Fanuc, ensuring intuitive operation and seamless integration on the shop floor.
Optional equipment includes high-pressure coolant-through-spindle systems, automation solutions, and integrated probing systems, enhancing productivity and efficiency. The machine is also prepared for future 4th or 5th axis upgrades.
Proudly supplied and supported in the UK by DTS (UK) Ltd, the IBARMIA Z Extreme 3-Axis is a testament to advanced engineering, providing manufacturers with a robust solution for high-value machining applications.
View more news from DTS (UK) Ltd
