Heavy-Duty Geminis GT7i G4 Lathe Unveiled in UK
Wednesday 28 January 2026, 9:42:31 AM
The Geminis GT7i G4 lathe, a formidable addition to the manufacturing sector, is now available in the United Kingdom through DTS (UK) Ltd. This robust flat-bed horizontal CNC lathe is specifically designed for machining oversized workpieces, tackling tasks where stability, torque, and accuracy are non-negotiable.
Built with a rigid cast-iron construction and featuring hardened and ground guideways, the GT7i G4 stands out for its ability to handle heavy roughing, large diameters, and lengthy components while maintaining superior precision. The machine supports substantial loads between centers, ranging from 12,000 kg up to an impressive 25,000 kg, with workpiece lengths spanning from 1 meter to 24 meters.
A key aspect of the GT7i G4 is its customizable high-power headstock options. Its main motor configurations range from 51/78 kW to 95/140 kW, delivering the torque essential for heavy cutting applications. The machine also offers a spindle speed range designed for high-torque, large-diameter machining, reaching maximum speeds of up to 800 rpm. The four-guide configuration enhances usability by allowing easier loading of long parts with movable carriage and steady rests on different slides.
Available with Siemens or Fagor CNC systems, the GT7i G4 ensures precision, reliability, and straightforward operation. Optional equipment includes manual or CNC-controlled steady rests, hydraulic tailstock, automatic tool turrets, advanced coolant systems, and comprehensive guarding and enclosure options, allowing for tailored machine setups to meet diverse industrial needs.
Supported by DTS (UK) Ltd, the GT7i G4 is targeted towards industries seeking reliability and accuracy in machining large-scale components. For more information and a tailor-fit configuration, potential clients can contact the DTS team directly.
View more news from DTS (UK) Ltd
