GER CM-CNC Cylindrical Grinder Sets New Standard in Precision
Friday 9 January 2026, 11:45:54 AM
The GER CM-CNC series, a cutting-edge cylindrical grinding machine, has emerged as a standout solution for industries demanding high-precision external grinding. Manufactured by GER Máquinas Herramienta S.L.U. in Spain, this machine showcases a remarkable blend of rigidity, accuracy, and reliability, supported and distributed in the United Kingdom by DTS (UK) Ltd.
Built on GER’s time-tested cast-iron construction, the CM-CNC series is engineered to deliver exceptional stability over extended grinding operations. Its robust design incorporates advanced CNC controls featuring the FANUC 0i-TF system. This provides seamless axis interpolation and reliable motion control, ensuring the precise execution of grinding tasks.
Key features of the CM-CNC include its extraordinary capability for external cylindrical grinding, supported by multiple length and diameter options that cater to various shaft and component requirements. The machine’s enhanced rigidity is attributed to its stabilised perlitic cast-iron bed and slideways, designed to dampen vibration while maintaining long-term geometric accuracy.
The CM-CNC’s precision-balanced wheel spindle contributes significantly to its capability, achieving excellent roundness and superior surface finishes crucial for industrial applications. Moreover, GER’s intuitive grinding software features a graphical programming interface that allows for quick setup, cycle optimisation, and support for ISO-code programming of complex profiles.
The series also offers optional equipment such as internal grinding spindles, automatic loading/unloading systems, in-process measurement and gauging systems, and a C-axis that facilitates profile and non-cylindrical grinding applications.
As businesses strive for enhanced precision in manufacturing, the GER CM-CNC series stands out as a dependable partner, combining cutting-edge technology with user-friendly operation to meet modern production demands.
View more news from DTS (UK) Ltd
