Sliding-head lathe cuts tungsten bar 12 hours a day
Tuesday 12 August 2025, 11:03:49 AM
Ten percent year-on-year growth in global sales since the start of the decade, and similar success confidently expected in the coming years, has prompted First Light Lamps to replace some of the 1980s- and 1990s-built turning machines at its Ely, Cambridgeshire factory with two new models that are more reliable, capable, productive and accurate. Producing 120,000 xenon and krypton lamps annually for laser and IPL (intense pulsed light) systems, used widely for medical and industrial applications, the company is the leading manufacturer of its type in Europe and among the three largest in the world.
Two legacy Miyano fixed-head lathes and a Cincom sliding-head turning centre have been removed to make room for two modern Cincoms, which were delivered in May this year (2025) by Citizen Machinery UK. The lathes will not only machine all the electrodes and connectors previously produced by the three old Citizen lathes but, when they are fully on-stream, will also allow the 10 percent of the company’s components currently being subcontracted out to be manufactured in-house. It will be a considerable financial saving and will also give the factory complete autonomy over its parts machining and lamp assembly.
The smaller of the two new Cincoms, a 12 mm bar capacity L12-VIILFV, is devoted to machining lamp electrodes from lanthanated tungsten bar, 1.5 to 2 metres long, of various diameters between 2.8 mm and 9.5 mm. The job was
previously done by two of the old Miyano fixed-head lathes, which were purchased second-hand in 2004 when First Light Lamps was founded. It is notable that, being of 34 mm bar capacity, they were deliberately over-specified in terms of size to gain the rigidity of a bigger production platform for machining the tough material.
Paul Walker, a director of the lamp manufacturing firm said, “We were initially sceptical that a sliding-head lathe, especially one of 12 mm capacity, would be robust enough to machine tungsten all day long.
“However, Citizen Machinery assured us that this model would be capable of doing so and cut demo parts using our tungsten bar to prove it.
“We didn’t even have to visit their technical centre. They simply emailed us a video of the lathe cutting our parts and then sent them to us so we could inspect them on our shadowgraph.”
The L12 was supplied fitted with an extractor to remove tungsten dust from the machining area. The use of coolant is not feasible, as it would result in a highly abrasive slurry that would prematurely wear the machine. Surprisingly, the carbide cutting tools in the machining area are the same as those recommended for machining aluminium, despite the toughness of tungsten, as their rake angles and chip evacuation capability are found to be well-suited to cutting the lanthanated material, which is more ductile than pure tungsten.
The compact sliding-head lathe is more efficient than its 18 mm bar capacity predecessor, especially with regard to its driven tool capability. It allows a hole to be drilled in-cycle in one end of the electrode to an accuracy better than was
possible previously on a manual lathe, so saving an additional set-up and machining operation. Moreover, the overall 30-second cycle time is no longer than before, despite the extra operation.
Three smaller old Miyanos are being retained to perform a second operation to shape a porous, impregnated tungsten billet after it has been brazed onto the other end of each turned tungsten stem. Notable about these lathes is that, although they were built in the 1980s, they are still able to hold tolerance after 40 years of service.
Regarding connector machining, their production from stainless steel, brass, copper or plastic bar between 6 and 16 mm diameter and up to 3.7 metres long has been transferred from the former 1997-built sliding-head lathe to a new Cincom L20-VIIILFV. Thanks to the machine’s greatly enhanced specification, there has been a four-fold reduction in cycle time from typically two minutes down to 30 seconds.
According to Mr Walker, the aesthetic appearance of the machined surface finish is considerably better than before, another indicator of the rigidity of modern Citizen lathes. Additionally, those connector variants requiring cross drilling and flat milling can now be produced in-house, whereas previously they had to be bought in. Drawing tolerances are down to ± 0.05 mm and all parts go for inspection.
There are 500 designs of electrode and a similar number for connectors, which underlines the need for machining to be wholly controlled in-house, as well as lamp assembly. Subcontracting out such a variety of parts would be incredibly difficult to control. Component batch size is low for sliding-head lathes, around
1,000-off, to support lamp assembly quantities of 50 at a time across a catalogue of 2,000 varieties. Such small volumes supplied by a subcontractor would be expensive, which is another good reason for bringing all machining in-house at Ely.
Musing on the future of the company, which he owns in partnership with managing director Martin Churchley, Mr Walker concluded, “Our new, highly capable Citizen lathes, despite being fewer in number than previously, produce four times more connectors during our 6.00 am to 6.00 pm day shift, as well as all of our electrodes, many of which we were previously having to buy in.
“The bar-fed turning centres have the capability to run 24 hours a day, overnight without supervision, which would have been impractical with the old machines. It has the potential to double production output and underpin our 100 percent in-house manufacturing capability for years to come.
“The support provided by Citizen over the years has been extremely helpful, even though we were operating second-hand machines, so we had no hesitation in returning to them when we were in a position to buy new lathes.
“They were supplied as turnkey installations complete with programs and tooling, based on the successful demonstrations at Citizen’s technical centre, so production started immediately after they were delivered and our staff had been trained.”
