ITC highlights full-line solutions at MACH
Thursday 21 March 2024, 9:37:17 AM
On Stand 432 in Hall 20, Tamworth cutting tool manufacturer ITC will excite manufacturers with its latest product lines that will appear alongside cutting tool solutions from BIG KAISER, WIDIA, Karnasch, Kemmler and Bass.
ITC will showcase solid carbide end mills, drills and thread milling ranges and much more. Among the crowdpleasers will be the 4101 Series of solid carbide lollipop cutters. Perfect for reaching the most challenging of surfaces when 5-axis machining, the 4101 Series is a 4-flute long-length tool with centre-cutting to reach the most inaccessible of surfaces – demonstrated by its 220 degrees of inclusive cutting. Manufactured with an AlTiN coating and a 30-degree helix, the 4101 Series is ideal for applications on steel, stainless, cast iron and aerospace-grade alloys. With ball diameters from 2 to 16mm, shank diameters from 6 to 16mm and an overall length of up to 100mm, the 4101 Series offers incredible rigidity, flexibility and surface finishes when machining the most challenging of parts.
For trochoidal machining, ITC will demonstrate its extensive portfolio with the 5021, 5031, 5041, 6051 and 6054 appearing as just a few of the stand-out performers.  The 5021 Series is a long-reach Cupro-coated 5-flute end mill with harmonic fluting and a variable helix for unsurpassed performance under the most challenging of cutting conditions. Accompanied at MACH by the short-length 5031 and the necked 5041 Series, the end mills are available from 3 to 20mm in diameter. The 5-flute trochoidal tools will be accompanied by the 6-flute 6051, 6071 and 6054 Series which are perfect for machining steel and exotic materials.
For the machining of aluminium, MACH will provide a launchpad platform for the 3301 and 3204 Series of end mills. The 3301 for heavy material removal is a long-length 3-flute series with a centre-cutting 38-degree helix geometry and impressive reach characteristics that are matched by its stability. Available in diameters from 6 to 20mm, the 3301 is available with an overall length of up to 150mm.
For long reach applications that demand maximum stability and impeccable surface finishes, ITC will present the 4104 and 4204 Series of 4-flute aluminium tools with chipbreakers.
ITC has also built an enviable reputation as a benchmark manufacturer of full-form threadmills, mini threadmills and single-point threadmills – all will be presented at MACH 2024. As expected from a leading manufacturer, ITC’s portfolio includes metric, metric fine, UNC, UNF, BSP, NPT, UNJC, UNJF and MJ thread forms as well as a recently introduced range of 60-degree single-point carbide threadmills. This new line of rigid high-performance threadmills enables the tool reach to be extended to produce deep-hole threads.
Complementing the extensive ITC range is a huge portfolio of WIDIA general purpose taps that are primarily manufactured from HSSE material and the BASS range of taps made from HSSE-PM – both applied to different parameters and material types. Both ranges are available in metric, metric fine, UNC, UNF, BSP, NPT, UNJC, UNJF and MJ thread forms, catering to the complete needs of your machine shop.
