CERATIZIT to grip MACH crowds with new innovations
Thursday 21 March 2024, 9:37:17 AM
CERATIZIT UK & Ireland will once again be at MACH, on Stand 340 in Hall 19, to bring the very latest in cutting tools and cutting tool technology to the exhibition.
As an industry-leading cutting tool company, CERATIZIT’s advancements in the engineering industry ensure they have a reputation for impeccable quality and performance – this will be demonstrated at MACH. As a leading innovator in the world of cutting tools, CERATIZIT has an ever-growing catalogue with new developments in tooling, many of which will be available to view in Hall 19 on Stand 340. With an enormous display of cutting tools and workholding solutions, the stand will be a huge attraction to manufacturers attending the event.
True to their ethos as a company dedicated to delivering unbeatable technical support and customer service, the MACH stand will be manned by more than 40 engineers to ensure that anyone wanting to enquire about working with CERATIZIT gets the chance to have a positive conversation. Alongside the countless product lines and technical expertise the engineers will be bringing to the stand, there will be a huge selection of innovations that have been introduced to the market in the last 18 months. All the product lines at MACH will be displayed on stands designed and machined in the CERATIZIT UK Technical Centre.
Amongst the huge selection of tools at MACH will be three highlight products that CERATIZIT will be showcasing during the exhibition: the HyPower, the WPC-Change and the MonoThread. The WPC-Change is an indexable insert drill that ensures high-quality machining doesn’t have to come at a high price. The WPC-Change and Change UNI combine the well-known advantages of Ceratizit’s WPC high-performance drills with the flexibility of an exchange system. This allows for fast changeovers, reduced machine downtime, reduced material consumption and incredible machining results and productivity.
Whilst being an affordable machining solution, the WPC-Change system is also extremely accurate, capable of producing precision holes with diameters from 14 to 30mm and hole depths of 3XD and 5XD. The wear-resistant holder makes them durable and ideal for repeated machine use. Except for the solid carbide indexable insert, the WPC-Change drills are made from completely reusable materials. This offers a low-waste, sustainable drilling solution. Specialised for machining steel and casting materials, the WPC-Change drilling system is a proficient all-rounder for use in any machine.
Moving from drilling to hydraulic chucks, CERATIZIT’s expansion of its HyPower hydraulic chucks means that even the most difficult machining requirements can be met with ease. For rough and demanding machining operations, the HyPower Rough is tough enough to take on any challenge. For optimum accessibility in the machining zone, the HyPower Access 4.5° offers itself as a highly flexible adapter for machining contoured components. The chucks come in 16 and 20mm diameters for a 32mm cylinder diameter as well as in variations of 16, 20 and 25mm for a 40mm cylinder diameter, which all will be on display at MACH.
On the thread milling side of cutting tool innovation is the MonoThread, a champion of CERATIZIT’s performance line. Delivering a performance improvement of 20% on competitor products, this thread milling cutter enhancement is ideal for all standardised thread profiles with tight tolerances. The MonoThread is ideal for asymmetrical, thin-walled, large or very expensive workpieces. The solid carbide shank thread milling cutters can be used to machine any material, including high-strength and tempered steels. This means that its performance is guaranteed even in tough machining conditions. For customers looking for a thread milling cutter that will deliver unbeatable performance, CERATIZIT will be highlighting different sizes and variations of the MonoThread on the stand.
