Ultimate stability and accuracy with Rainford Precision’s KERN machine
By Rowan Easter-Robinson
“You don’t put cheap tools on an expensive machine!”
Do you want the ultimate in accuracy, repeatability, and surface finish? Then you need the best tool! At MACH 2024 on the Rainford Precision stand, these incredible demonstrations can help you make hundreds of good components reliably on the KERN machine!
MTDCNC’s Rowan Easter-Robinson is with Miles Evans of Rainford Precision to understand the process behind achieving an ultra-high precision finish on components made of copper. KERN is a quick and highly temperature-controlled machine that delivers enhanced stability – so you can achieve 99% in-tolerance parts 24/7!
