Dot Peen – Portable
Thursday 4 March 2021, 10:46:15 AM
SIC Marking is an international group developing permanent marking solutions and automatic reading systems (datamatrix) for the traceability of industrial components. SIC Marking offers a complete range of dot peen, scribing and laser marking machines.
With 30 years of experience, SIC Marking develops traceability applications for a wide range of materials such as steel, alloys, stainless steel, titanium, aluminum, and plastics. Today we work with professionals in various industries such as: automotive, aerospace, metallurgy, mechanical engineering, plastics processing, railway, medical, construction, defense…
With an experienced, responsive and involved team, SIC Marking offers a complete range of standard products, and custom machines to meet all your needs.
dot peen technology : fast, efficient marking on any material!
Dot peen marking works by electromechanically striking a carbide or diamond stylus assembly against the surface of a part to be marked.
The result is a succession of dots to create digits, text, logos, and 2D data matrix codes. Each dot is the result of a pulsed currentthat runs through a solenoid, punches a magnet toward the surface, and subsequently returns the stylus to its starting position,awaiting the next pulse. Because each pulse occurs in only a fraction of a second, an entire 2D data matrix code, for example, can be completed in seconds (depending on the size). Frequency can be adjusted by controlling the speed of the X and Y axes movements.
What makes SIC Marking’s dot peen technology so unique is the constant measurement of the electrical current between each pulse. This allows for constant, precise control of the impact consistency.
Dot peen marking works by electromechanically striking a carbide or diamond stylus assembly against the surface of a part tobe marked.
The result is a succession of dots to create digits, text, logos, and 2D data matrix codes. Each dot is the result of a pulsed current that runs through a solenoid, punches a magnet toward the surface, and subsequently returns the stylus to its starting position, awaiting the next pulse. Because each pulse occurs in only a fraction of a second, an entire 2D data matrix code, for example, can be completed in seconds (depending on the size). Frequency can be adjusted by controlling the speed of the X and Y axes movements.
PORTABLE : LIGHT AND BALANCED
Our portable range offers lightweight, totally mobile, and ruggedly constructed marking systems that are ideal for marking heavy or difficult-to-access parts. Our portable range has been specially designed for marking almost any sized part, no matter how small, bulky, or awkardly shaped.
These high speed, powerful marking systems will work on any material, including plastics and hardened steel up to 62 HRC, all with a constant level of quality and accuracy. Ownership and operational costs are very low, and no consumables are required for use.
ROBUST AND RELIABLE
• Designed for industrial environment
• Oversized components offering unrivalled
longevity.
SIMPLE AND USER-FRIENDLY
• Lightweight
• Mobile, ergonomic, and versatile
• Simple programming
HIGH PERFORMANCE
• 100% electromagnetic technology
• Constant precision and quality
• High speed marking
• Powerful integrated software
• Ideal for marking heavy or bulky parts,
up to 62HRC
LOW COST OF OWNERSHIP
• Low initial investment
• Reduced maintenance
• No consumables
WIDE RANGE OF OPTIONS
