Save Money with Contrinex Ceramic Coated Weld✨-Immune Inductive Sensors and Improve OEE – www.Weld.PLUSAx.co.uk
Tuesday 3 May 2022, 6:30:27 AM
Reduce sensor failure in welding applications with Contrinex’s uniquely robust ACTIVSTONE® ceramic coated inductive sensors. Contrinex offers weld-Immune inductive proximity sensors, differentiated by three unique features, to offer the best performance and longevity, whilst being able to withstand high-intensity magnetic fields.
ACTIVSTONE® CERAMIC COATING
An upgrade in resilience to weld-splatter and providing easier cleaning than the PTFE coating offered by competitors, Contrinex offers a unique high-performance ceramic coating option. The ACTIVSTONE® coating provides high levels of durability from both heat and abrasion. It reduces the accumulation of weld spatter and can withstand cleaning with wire brushes giving a longer sensor life, fewer machine break-downs and improved OEE.
No alt text provided for this image
Custom-designed accessories, including fixing nuts and mounting brackets, are also available with the ACTIVSTONE®-coating. Heavy-duty PUR cables and optional high-temperature-rated spatter-resistant shrouds to prevent cable damage also contribute to robust sensor systems.
Combining exceptional durability in harsh environments with extended working life, Contrinex’s enhanced Weld-Immune sensor range is a highly affordable, risk-free option for systems integrators and equipment designers in diverse industries, including automotive, aerospace, electronics and white goods.
 IMPACT & ABRASION RESISTANCE
Contrinex offers Weld-immune sensors as part of their EXTREME 700 Series, which offer exceptional robustness and long sensing distances. They feature a housing machined from a single piece of stainless steel with a thick front face which provides extraordinary abrasion resistance. The sensor’s unique technology gives it unmatched abilities to resist shock and impact damage – This is typically demonstrated by showing a sensor surviving being used to hammer nails into a wooden block.
CHIP IMMUNITY
Contrinex incorporates its ‘Chip-Immunity’ technology into the weld-immune sensors to enable them to continue to work reliably even when its front face has collected a build-up of weld-spatter.
LONG SENSING RANGE TO KEEP OUT OF TROUBLE
The 700 Series sensors also benefit from true ‘Factor 1’ sensing, which can sense steel and aluminium targets equally effectively at up to an 8mm distance. Therefore the sensor can be positioned further away from potential damage from moving parts and the build up of weld-spatter.
PRODUCT ADVANTAGES
Low-cost 600 Series – All-metal housing & PEEK polymer sensing face, Uniquely robust 700 Series – One-piece stainless-steel (V2A /AISI 303) housing and sensing face, Robust & reliable in demanding conditions, ️ Excellent temperature stability & temperature-resistant, ✨ Immune to electromagnetic interference from 50Hz and Medium-Frequency weld fields, Excellent sensing of small & thin targets, Factor 1 sensors offer equal sensing distance for steel & aluminium targets, Ceramic ACTIVSTONE coating option, ️ IO-Link – Ideal for Industry 4 and offering Plug and Play swap-out.
Read more at the Product Page, Click to download the Contrinex Weld-immune flyer, or Click to download Contrinex’s Product Overview brochure to find out more.
PLUS Automation Ltd is the importer of Contrinex sensors into the UK and Ireland, and can help you #MakeSenseofSensors to solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional Inductive , Photoelectric , Ultrasonic , RFID & Machine Safety sensors.
