‘It’s Getting Hot Out There’☀️, But Contrinex High-Temperature☄️ Rated Inductives Can Be Relied Upon – www.Temp.PLUSAx.co.uk
Contrinex’s high-temperature rated Inductive sensors can operate 230°C and sense at up to 25mm, whilst maintaining excellent performance due to their industry-leading temperature stability.
Contrinex HIGH-TEMPERATURE inductive sensors excel in every respect, being designed for continuous operation at temperatures up to 180°C, or up to 230°C using the versions which place their electronics remotely in a small module positioned two metres away along the sensor’s cable.
The HIGH-TEMPERATURE inductive range is ideal for the harshest environments, including automotive paint shops, metal-treatment plants and glass manufacturing, combining ultimate accuracy with world-class reliability.
PRODUCT ADVANTAGES
️ Continuous operation at temperatures up to 230°C, Exceptional Temperature Stability, Robust Stainless steel construction, Long sensing ranges up to 25mm, Small sensors with integrated electronics for temperatures up to 180°C, Compact electronic module (eg M12 x 65mm) integrated into the cable for temperatures up to 230°C, Highly Reliable with Long Service Life
Contrinex also offers EXTRA TEMPERATURE inductive sensors for lower temperature application, with consistent temperatures of up to 120°C. These sensors offer the ideal solution for position and presence sensing where temperatures would damage a normal inductive sensor.
The stainless-steel construction and robust electronics of Contrinex EXTRA TEMPERATURE inductive sensors ensure reliable, accurate operation and minimal downtime in the most demanding environments.
PRODUCT ADVANTAGES
️ Extended temperature range from -40°C up to 120°C, Excellent price-performance ratio, Exceptional Temperature Stability, Robust Stainless steel construction, Sensing ranges up to 5mm, Highly Reliable with Long Service Life
Read more on the Product Page, Click to download the Product flyer, or Click to download Contrinex’s Product Overview brochure to find out more.
PLUS Automation Ltd is the importer of Contrinex sensors into the UK and Ireland, and can help you #MakeSenseofSensors to solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional Inductive , Photoelectric , Ultrasonic , RFID & Machine Safety sensors.
