Inductive Sensors Verify Cannula Selection in Robot-assisted Laparoscopic Surgery ‍⚕️
Friday 16 April 2021, 6:37:48 AM
Contrinex’s Inductive Sensors Verify Cannula Selection in Robot-assisted Laparoscopic Surgery ‍⚕️ – www.600.PLUSAx.co.uk
Laparoscopic surgery has started using robot-assistance and a key issue these systems face is ensuring that the correct length and diameter of cannula or trocar has been loaded into the robotic manipulator before insertion into the body cavity.
CUSTOMER APPLICATION
To perform robot-assisted laparoscopic surgery, the surgeon sits at a computer console viewing a 3-D image of the surgical field and guiding surgical instruments via joy-sticks. The improved depth perception and rotational movement provided by a robot has extended laparoscopic surgery to more complex procedures. These require cannulas of many different types, each individually identified by ridges and grooves machined into the area clamped by the robotic member.
If the wrong cannula type is fitted it may be too small for the tools required or too large for the intended procedure, with potential harm to surgical outcomes. It is therefore essential that the robotic system should check the cannula before allowing the surgeon to proceed with surgery.
A non-contact solution is required. Space constraints around the robot also make small size essential.
CUSTOMER SOLUTION
Contrinex’s ‘Basic’ range of inductive sensors (600 series), are installed into the clamping block of the robotic member and utilise their high-performance sensing capabality to detect the presence of machined ridges and grooves in the cannula.
The groves provide a binary code that identifies the specific dimensions and profile of the cannula loaded. Detection is accomplished through the wall of the mounting block, isolating the sensors from the surgical device.
Space constraints require these 6.5 mm diameter sensors are mounted side by side with no spacing, essentially violating mounting rules. To avoid the possibility of cross talk or mutual interference the sensors are powered on and off sequentially and their output status monitored.
Sensor data delivered to the control system allows the surgeon to proceed with confidence that instrument movements within the patient’s body will be dimensionally correct and the internal size of the cannula is sufficient for entry of the surgical tools required.
PLUS Automation aims to help #MakeSenseofSensors, helping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional Inductive, Photoelectric, Ultrasonic, RFID & Machine Safety sensors. Find more information and read other application examples go to www.PLUSAx.co.uk
PRODUCT ADVANTAGES
 ‍Fast and accurate detection
 Long sensing ranges
 Robust and & reliable
 ️IO-Link – Ideal for Industry 4
FIND OUT MORE
Find out more at www.600.PLUSAx.co.uk, or Click to download a flyer, or Click to download Contrinex’s Product Overview brochure
PLUS Automation aims to help you #MAKESENSEOFSENSORShelping solve applications, improve machine performance and reliability, and reduce costs using Contrinex’s exceptional choice of sensors.
